3FE fuel Supply problem - Please Help!
lelandEOD
Dayton, Nevada
So, long and short: my 3FE FJ40 has been giving me grief for some time now. Some of the symptoms I'm experiencing are: loud fuel pump, hesitation and stumbling under load when the engine gets hot on a warm day, and occasional knocking/pinging while driving up grades at highway speed.
So, tonight, I played around with it and as I'm laid under the truck with the engine running, I watched the fuel pass through the glass pre-filter I've got just upstream of the fuel pump. There were bubbles mixing with the fuel and the pump was making it's usual labored whine.
I decided to make sure I didn't inadvertently do something goofy with my connections to the Pollak valve that switches from the front to rear tank so I used a pair of vice grips to pinch off each line to make sure I had the supply and return lines hooked up correctly.
Here's the interesting part: When I pinch off the return line the oddest thing happens... the bubbles in the glass filter disappear, the fuel pump instantly goes silent, and the engine sounds like it's idling better. I watched the screen in the fuel filter and can even see it flexing or distorting, as if under strain, as I pinch and un-pinch the return line. When I pinch the return line, it relaxes and when I un-pinch the return line, I can see it suck inwards as the fuel pump strains to suck fuel through it.
I took it for a test drive around the neighborhood and it is running much better if I leave the fuel return line pinched. The stumbling/hesitation is gone and although I won't know if this solves the pinging until I drive up a long grade, my suspicion at this point is that the pre-detonation was being caused by fuel starvation affecting the fuel/air ratio.
Now, I'm completely perplexed because I don't know why the fuel system is behaving this way. Everything is new... pre-filters, fuel pump, engine fuel filter, fuel damper, fuel pressure regulator, benched, flowed, and rebuilt fuel injectors, etc.
It would seem to me that there is a problem with the fuel pressure regulator not allowing the pump to build enough pressure but I have absolutely NO idea why I'm getting air bubbles in the fuel supply unless I pinch the return line off.
Please help.
May have a bad pressure regulator 100 % fuel pressure, or you may have a blocked fuel pickup. BTDT. Our solution was to toss the pump from the frame position and plant an 80 series pump on the tank. Works great!
Lots of fab work. Weld 80 wounding ring into 40 tank and make pressure tight. Shorten 80 pump bracket. Also made baffles/traps inside tank to insure lots of fuel always available to fuel pickup. fI really hates air bubbles in fuel supply. John
