Nice ressurection there, Matt.
Pert near 3 year old thread.
Thanks to all of you 3fe power adder pioneers. I'm ab to crack mine & do a similar build:
Forged internals
RV grind cam / lifters
Headers
Hi flow cats
Full exhaust
Bored TB
Injectors
Jet CPU tune
Hot tank / steam clean intake manifold
De smog
Hopefully the beast will roar
I agree, my truck hauls ass with the H55F on 31's. I have a similar engine to overhanger but no snorkel. I have, accidentally, gotten rubber in both 1st and 2nd gear. My rmp's are too high now so I will do a rubber re-gear to 33's to drop them down. Make sure your TPS is adjusted properly and spend the $260 for a overbore TB from RC. Well worth it.
My H55F conversion cost about $3200 using a new H55F, clutch, master, slave, etc. and a bunch of used FJ60 parts. Done in my garage.
My 3FE rebuild cost about $2500 using new OEM pistons, cam, oil pump, etc etc. I balanced the rotating assembly and its overbored 40 over. Oh, and Jim Chenoweth built my head using chevy SS valves and did some P&P work. Flowmaster as well.
I did all the work except the machining. The machine shop assembled my long block for an extra $200 and they had done many 2F and 3FE's so I let them!
Biggest performance improvement: H55F! Overbored TB next.
I do not need a V8 in this truck it hauls ass! If you do not want to go manual get an extreme A440F from Slee and put your foot in it.
Dunbar
Virtually no difference at all. Just look inside the air meter, it's a much smaller opening than the throttle body. The factory (quite large) air filter will not really be a restriction.A friend of mine has some sort of a cold air intake on his 3FE.
I test drove it and it feels like it has some good torque, off the line, power.
Acceleration is not super, but just the start from stopped kick feels a little more.
Does less restrictive air intake flow affect off the line torque? My guess would be no. I would think that would only help with horsepower at higher revs where air flow comes into play.
Anything I said make sense?
It's almost always the heads and cam that are the main limiters of power.Is the head what really limits the power on these things? There are plenty of old I6's that can make some pretty serious power, seems these should be able to as well. I'm guessing the lack of aftermarket parts doesn't help.
Supposedly the cam & lifters as apackage will yield 20-25% improvement. If I can squeeze out 1fz numbers and turn 35's in the mud, I'LL be happy.
