So, sadly I wasn’t paying attention… on first start up after turbo install on my 3b I had a rag in front of the turbo and it sucked it in. (It was running perfectly for 5 mins before it happened.) I ran to turn it off, I’m not sure if the rag or the key shut the motor off first but ether way…
I pulled the rag out and nothing is missing from the rag. The compressor wheel and everything seems fine, so no issues with the turbo or rag being sucked in I don’t think.
But my question is, why won’t the 3b start now? Cranks fine? Did I wreck the fuel pump diaphram by blocking off the intake?… is there a diaphragm? Must be with those two vacuum hoses coming from the intake into the pump?… don’t know much about how the fuel system works on this motor… Will look more into it tomorrow, but wanted to see if anyone had ideas on it…
Also forgot to mention EDIC was working before but now the arm is stuck in the off position so I disconnected the arm so the pump is in its resting positing… the drive spot on the pump?… what is that big round thing that the arm on the pump hits if I push it towards the over inject spot? looks like stop of sorts but why so big and with a hose on it?
Any advice would be appreciated… thanks, feel pretty stupid forgetting that rag.
