35s v's 37s
Skippy's Wonderland (OZ)
Im considering running 2 sets of tires - 1 for road and 1 for off rd. I currently run the 35in MT baja claw radial on and off and they are due for replacement by xmas so im considering running the claw in 37in radial for off rd and something nice for on rd.
I prefer the radial even as an off road tire as there is usually some distance involved in getting to a location and they drive much nicer on the black top and Im happy with their performance off rd as well.
So my question is: Is there any major benefit to up grading to 37s over 35s in terms of performance or am i better off with the 35s and spending more time driving the tracks rather than changing CV's ?
I service my truck regularly and its always in tiptop shape. I also do my own bearings etc though im really not sure how much extra stress the 37s will place on the drive train ?
The 80 is double locked and ive changed the gears to 4:56's. Ive never broken a CV "yet" even with the beating its copped. Im sure its bound to happen sooner or later I just dont want to push my luck If those of you who run 37s are breaking CV's all the time.
PS: Im not interested in running hardened CVs as ill only end up breaking diffs instead - much harder to fix in the middle of nowhere.
Thanks in advance.
Regards,
Nath
I ran 35s for a while on/off and found I broke more because I couldn't get over things as easily as I can with 37s. I do run longfields up front and poly performance in the rear, and the only issue i have had was a broken ring gear up front due to chipped tooth from back when I ran 35s.
I also had a BIG change in tire type. Went from MTRs to Iroks...HUGE difference in how much wheel spin I needed to do most stuff here in the southeast. MTRs suck down here :)
Good luck with everything.
dan-- how do you know that the chipped tooth happened w/ the 35's ? just curious, i may have not read the last posts on your diff delima, but it wasnt from the gear setup?
If you need 37's for the wheeling you do, then you should run them. Being undersized in tires for the wheeling you do may be your single greatest liabilty. If you don't, then run a single set of 35" tires.
4.56's are not enough gearing for 37's, you'd want 5.29's.
depends...
Lot of people are fine with 4.10's and 35's, 37's and 4.56's shouldn't be any worse. and by fine I mean they're happy with them, not that they are the ideal set-up.
Possible. I chipped the tooth a long time ago when I blew a birfield but let it go since it wasn't making noise. I was running 35" MTRs and was having to use more momentum due to the tire size and composition.
The tooth finally let go this month when I hit a 3 foot deep water hole going 35 (went from 6" to 3' in a flash). Ooops!
Make more sense?
depends...
Sure, I was one of those guys until pushing the crawling called out my lack of gearing. If you really "need" 37" tires, you really "need" low gearing. At my elevation for wheeling (generally 9K feet and above), I'd take my 80 on 35's and 5.29's over an 80 on 37's and 4.56's.
I'm not saying you can't do it, given I tried my best to make 4.10's and 35's work with reasonable success (I am not an every weekend wheeler), but if I needed a whole additional tire size class for the trails I wanted to run that kind of ungearing would be a critical issue, because I don't run trails that "require" 37's and I finally got to struggling badly with just the 35's on the 5 or 6 good rock crawling runs I do a year. Elevation is a major factor for me, though.
I'm about 600ft above sea level, and hoping the sea will rise about 599 ft.
Lots of flat hwys here, 75mph speedlimit, and run just over 75 indicated, so the rev's are right where they should be, even if the speed is higher than advertised. I also don't tow a whole bunch. That's why I said "it depends".
4.88's would be like 4.56's on 35's, which is where he's sitting now, which is about the same as 31's or 32's on stock gears.. 5.29 seems a bit severe... all DEPENDING on how true a 35 we're talking about siunce they run from 34.0 to 35.0, and I"m guessing 37's are all 37.0 either.
so, I'll stick with "it depends, you might be satisfied, you might not"
because I don't run trails that "require" 37's and I finally got to struggling badly with just the 35's on the 5 or 6 good rock crawling runs I do a year. .[/QUOTE]
Good points. I need lower gears asap. just finished st george. going to prescott az next week.
But what does "require" mean? you could get an eldorado up many trails with enough beating. My little brother makes a habit of taking underequiped rigs on group trail runs just to prove a point to doubters. he has got a sidekick into places you would not believe. now he is taking a bone stock flatfender on some crazy runs. we all know guys like these. and an 80 will never be hardcore unless it can lose 1500 lbs. Just ranting Nay. you know all this
But my point is that if I am going to be hung up on stuff or suffer worse gearing by going with the larger tire I will take the bigger tire. I guess when you say "require" you mean trails that will get hung up on 35's
Ok....
I neglected to mention that I will be fitting crawlers in the near future so gearing off rd will be excellent for 37s and id be running 35s on the blacktop so 4.56 is excellent for this as well.
35s off rd work well for what I wheel in however i was looking to justify the purchase of 37s if they were to be a whole lot better than 35s. Its not worth the extra money if its a 10% improvement and im more inclined to break stuff but I can justify it if the 37s perform substatially better across the playing field.
Regards,
Nath
If you are going crawler box...get 37s, you will rule.
that is my plan :)
No doubt, you can't justify a crawler box for 35's :D
