- Thread starter
- #41
1st world problems, eh?Haha the 200 section is the only one that has these tire pressure arguments... Maybe that is a good sign that the 200 is so good that there is nothing else to argue about. lol
Are you running perry bumps on all 4 front mounting points? You should only need 2.
Again thank you! Glam pics "IN COMING!"Yes, PParts; yes, all 4 fronts. Here's my offset (see pics in next post)... which is partly why. I'm nervous about the Falken's trying to eat my fenders.
Also, Turbo8 ... I JUST LOVE my low profile recovery points! You're another vendor I totally think is underrated and I'm extremely grateful for your wealth of knowledge and products.Again thank you! Glam pics "IN COMING!"
Thanks for the pics. Glad you got your ride sorted out and it was an easy fix.Glam shot for the EE boys! Thank you for your products!
Some pics of current offset I’m on methods 18x9 @ 25 offset. I bought custom spacers from Bora but don’t need them. This set up clears all the stuff “inside the fender”. Once I get bumps right I’ll let you all know if I still have fenders.
VWynn, go ask MTKid. It's his lift kit that he's developed with some of the more extreme LX guys from his area. They're all on Mud but they're not a boisterous group IMO but they'll have the deets for you. Also, you can follow this thread (see below) to get even more of the details.Truck looks good! Are you currently running a spare as well with that size?
also curious question, can you get pics of your CV angle at normal ride height? im curious to see how much it changes from non sensor lift.
Looks good. And yup I got the NST 1inch BM spacer, e&e front and rears. Just to get some aftermarket wheels before I commit to install lolVWynn, go ask MTKid. It's his lift kit that he's developed with some of the more extreme LX guys from his area. They're all on Mud but they're not a boisterous group IMO but they'll have the deets for you. Also, you can follow this thread (see below) to get even more of the details.
Search for: NST Spec Body Lift Kit
Regarding the spare tire, I don't have one right now. I'll work with Stellar Built down the road to get a spare on a bumper. Currently I run a patch-n-plug kits and a compressor. Rolling the dice a bit I suppose.
Low mode pic..
Sounds like a great build so far. Lot of aftermarket wheels to choose from. A bit of choice paralysis for me. Good luck and post those pics!Looks good. And yup I got the NST 1inch BM spacer, e&e front and rears. Just to get some aftermarket wheels before I commit to install lol
I didn't pay attention to this earlier. So you have two rigs now? When did this happen? I missed the news.I have a stock 2021 with 35s on it and it’s not bouncy. In fact the ride improved coming from the 21s. I’m running 36 psi in E rated KO3s.
which bumps did you get from PP in this picture? And which did you get to correct your issue?I feel hijacked.
Back to my other issue. I ordered wrong pump stops. Replacements coming. Will report findings after swapped.
Do you mean body lift and sensor lift? Or just adding spacers with the sensor lift for AHC pressures?which bumps did you get from PP in this picture? And which did you get to correct your issue?
Asking because i first purchased the "AHC Equipped: 41 mm" but i thought i picked the wrong ones because of how small they were when my plan was to do spacer lift + Sensor lift at the same time. This lead me to purchase "-1/4" Up-Travel: 52 mm" as recommended by Perry themselves. Im not curious if I made a mistake and maybe should have ordered the middle one? "OEM Up-Travel: 45.3 mm"
Thoughts?
You're right. It's too early for me to think clearly hahaRegardless of sensor lift or body lift.
Second on this!In the rear at least, the long travel PP bumstops are ONLY for rigs with a relocated lower shock mount. If you've just got coil spacers, you want the "standard" AHC one. Regardless of sensor lift or body lift.
Sorry I should have been more specific. Fronts will have E&E 13mm top hat spacer and rear will get the E&E rear shock spacer. With this combination I aim to max the sensor to get it at normal operating pressures, hense why I aimed to get both extended feont and rear bumps from PP.Do you mean body lift and sensor lift? Or just adding spacers with the sensor lift for AHC pressures?
You want the smaller spacer on the LX if you do a body lift kit. The longer ones are designed for when the suspension is lifted. For example on the longer ones I order, when we did the body lift, the vehicle was riding right on the bump stop. Even parked it was engage or just 1 mm from engagement. So these will be too long on a stock LX or LX+body lift.Sorry I should have been more specific. Fronts will have E&E 13mm top hat spacer and rear will get the E&E rear shock spacer. With this combination I aim to max the sensor to get it at normal operating pressures, hense why I aimed to get both extended feont and rear bumps from PP.
