Hey guys,
I need some help. I have a 92 350 tbi in my cruiser and I'm having some problems. Here is what I have.
Stock internals
Tbi spacer with moded tbi ( smoother bores and milled throttle blade shafts. for more air.
Blocked off EGR.
I have a fuel pressure gauge on the tbi and it shows 13 psi even at wot.
The things starts and idles great but when you go to drive it , under loaed it bucks backfires and almost stalls. If you get past the stage(about 2000 rpm) it kicks in and will run at wot.
I set the timing at 0 deg with the connector unpluged and watched the timing when plugged in. The timing climbes smoothly.when you hit the throttle. the timming chain is new so no slop there.
It has only a crossover pipe on it with the o2 sensor in it so no muffler.
The only code it thows is a vss which I knew it would. That shouldn't make the that huge of a difference. oh the warmer it gets the worse it gets.
I need some help so please throw me some suggestions.
Stock internals
Blocked off EGR.
