- Thread starter
- #21
Template is a good idea, I don't think I can make it that pretty. Thanks again I post on the progress.
When I was having overheating problems, a 195 degree thermostat was the cure. My problem was the water was not staying in the radiator long enough to cool down.
HTH,
Howdy! Any good radiator shop can fix that problem. I had my lower outlet moved from the back of the lower tank to the bottom, and replaced it with a 90 degree turn. It is now about 5" from stock. I can run 20+ inch fan with no clearance issues. JohnI tried a big mechanical fan from a caddy, and it hit my lower radiator hose
Personally, I'd rather run the mechanical fan...is there a little smaller one that might work? or a reason why that fan would interfere with my lower hose? I currently run the Taurus fan.
I'm using the AA mounts.
Black Dog here's a good explanation of what's happening with the thermostat.
http://auto.howstuffworks.com/question248.htm
The way it was explained to me by a mechanic was after the engine heats up the thermostat opens. The hot water in the engine gets pushed into the rad and the cooler water get pushed into the engine. Since the cooler water is cooler than the rating of the thermostat, the thermostat closes. Therefore the hot water stays in the rad and cools down. Once the cooler water in the engine heats up, the process starts over. So therefore you need the right thermostat and the capacity to cool the hot water.
HTH,
If youre running a carb check that your not running too lean. Also, see if your cooling system doesnt have air in it. I know you burped it. But do a double check....
