350 hesitation
courtenay British Columbia
Hey all
so I got my cruiser on the road after doing a small block conversion :) it was running deadly lots of power but now seems to hesitate when under load. my motor is a 1994 targetmaster 350 with a aluminum intake and a quadrajet from a 85 vandura with a 305 (I think). timing is a@ 7btdc. also new cap rotor plugs and wires. so I think I might have something caught in my fuel pickup and it starves the engine. is this a common problem with cruiser tanks? I have an other tank from a 77fj40 which I plan on putting in cuz it seems to be in better shape.
also on the carb I have one hose fitting not hooked to anything, which I think used to go the the charcoal can. should I just plug it or should I get a charcoal can and hook it up??
also which connection on the carb is supposed to got to the dizzy?? when the carb was on the other motor it had some sensor thingy in the manifold with a hose to the vac advance?
any ideas?
What do you mean by "hesitate"?
If it bucks and spits back through the carb when you have it floored going up a grade, then these are classic signs of fuel deliver problems. If it just bogs down when you mash the skinny pedal and they it revs up fine, it may be the transition ports or circuits are plugged in the carb. A 305 carb may be jetted a little lean for a 350.
Depends on what hose fitting it is. Try plugging it for starters. Any open fitting can't be good.
The port that goes to the distributor is the one that has no vacuum at idle and increasing vacuum with engine RPM. Best I can do without pictures or knowing which carb it is. The "sensor" gizmo may be a thermal vacuum switch.
heres a pic of the carb setup i have the vac hooked to the port under the fuel inlet. i think it might be right. the one with the arrow is the one i am wondering what to do with ?
If it bucks and spits back through the carb when you have it floored going up a grade, .
oh yeah and that is exactly what it was doing :doh:
so i just switched the tank cuz I think that is the problem
It's been a long time since I have had a Q-jet, so I don't remember what that fitting does. Just from its size, I would guess it is a PCV port. Check for vacuum on it. If it has vacuum at idle you want to plug it. It is too big for a vacuum advance.
Fuel tank could be the problem but also anything in the fuel line between there and the carb.
The fitting arrow points to goes to PCV on my '77 350 with quadrajet. It was like that when purchased. Also, if you place a clear filter in-line with gas feed you may see debris coming from tank.
I'm running a 350 as well and agree that port ran to the charcoal canister. I have left it opened as I haven't finished tuning the engine. I was thinking that if you pluged it up it would probably lean out the mixture as it wouldn't be getting fumes from the charcoal canisiter. But I assume you could fix the mixture by adjusting the carb. I've also considered running the vent from the gas tank to it (just skipping the charcoal canister).
Can't help with the bucking and spitting. But fuel fliters are cheap, if you're worried about clogged lines, $5 would be a cheap easy place to start.
I'm interested to see what you find
Chris
well I guess maybee i should just plug it off since I dont have a charcoal can to hook it up to. but I was thinking of hooking it into the aircleaner good idea?
I have a clear view glass filter in the cab right off the tank so I can see the crap
my pcv is hooked to the fitting on the carb base plate and goes to the vavle cover pcv
well i decided to switch the tank yesterday so I hope that cures the burp spit thing
anyone have any pics onf their qjet setup?
Mr Greencruiser. First nice looking rig. Second having an open port on your carb is a bad idea it will only let in crap to the carb and affect fuel delivery. I have that port pluged off and my rig runs great. As for the hesitation, you may also have a fuel filter "screen" on your fuel inlet. Check that it my have some build up. although that would affect the hole performace of the carb. And actually it you have this remove it, as long as your using an inline filter you don't need it. Also check your plugs the color will give you some indication the your fuel mixture. Does your temp increase rapidly when you notice this hesitation? if so you might be lean under load.
HTH
well even after having changed the fuel tank and cleaned the filter the cruiser was still hesitating and the died right out. and i was totally confused. so i checked the filter again and there was some big wad of gas tank crap ( from previous tank) stuck right in the filter inlet. so i just blew it out!! now its fine
oh yeah I plugged that hose off my carb aswell :) thanks for all the advice everyone :beer:
