350 Conversion Question
I'm just about to tackle my pre-87' 290hp SMB 350 crate motor into my 71 fj40 with a 700r4 4L60E with AA to Toyota T/C project!
All the components are new.
I also am using a Edlebrock 650 cfm elec. choke with a matching intake.
Using AA motor mounts
Using the exhaust manifold out of a 86' full size blazer which dump inside the frame.
Top of the line fluids for break-in.
Am I missing anything! I have not yet pulled my F engine and am concerned about missing something!!!!
Any advice????
Thanks
Shawn
Any advice????
Thanks
Shawn
Speedo cable may not reach... Driveshafts will need to be modified. I'd be looking for a new radiator.... 290 HP is alot to cool.
I would use some Ramshorn exhaust manifolds and a crossover pipe (search for Texican's post). The edelbrock carb will not work very well on hills.
Watch out for clearance between the LH exhaust manifold or header to the steering gear box. It's a tight fit. I have nearly zero clearance with my headers, which AA sells just for this application. I've heard it both ways that the cast iron manifolds do, or do not, protrude as far as the headers. Probably depends on which specific manifolds are being used.
Any advice????
Thanks
Shawn
You will need a rear drive train mount. AA sells a crossmember that bolts to the back of the transfercase that a lot of folks use. If you use this style mount, I recommend using studs w/locktight in the transfercase instead of bolts.
You will need a shifter for the transmission.
You will need a skid plate.
You will need Radiator hoses, new battery box/mount, battery cables, sender adapters to retain the stock toyota gauges (oil, water), tansmission cooler (get the biggest one you can find), transmission cooler lines and fittings, transmission dip stick, and fuel lines.
I've found that the heater hose connections at the firewall may need to be modified depending on engine placement. You may need to even use a dofferent heater control valve and control cable.
You will need all the engine accessories like a air cleaner and housing, starter, pullys, belts, brackets, power steering pump, water pump, alternator, fan and spacer or fan clutch.
You will need a good fan shroud.
You will need to make wiring modifications for the charging system and starting system.
You will need exhaust pipes run from the manifolds to the rear of the cruiser as well as a muffler.
You will need a thermostat and housing, distributor/coil, spark plugs, plug wires, brake booster vacuum hose.
Depending on the exhaust design and manifolds used, you may need to make brake line modifications to allow clearance between them and the hot exhaust pipes/manifilds.
You will need a new throttle cable or perhaps you can modify the existing one.
I'm sure there's more I'm missing...
QUOTE]
Here's what Mike is referring to:
One of the heater hose connections can be seen in this photo at the rear of the valve cover. It's a tight fit.
Are you adding power steering at the same time? I did, it was not too much more work. Most of the stuff can be bought directly from flaming river, but AA sells the stuff too.
When I did mine, with the length of the NV4500, my engine sits a good bit off the fire wall, I put in an alumin radiator and electric fan. The fan only comes on when I am on the Freeways around here. (Our freeways now resemble LA traffic.) When it dose come on it is for less than 4 mins.
You will also need some time to line it all up BEFORE you start to weld. Take your time on this part. All the rest is bits and pieces.
Have fun, good luck, and be save moving around all the weight.
Good Ideas
Once I started to read some of the posts, I realize I forgot to mention a lot of the items I have.
I will be changing the stearing over to the Astro Van conversion.
I have a taurus fan setup to use...
I need to order a Lokar shifter yet
I do know that major driveline mods need to be done. I already have a top of the line shop for that.
I do have the AA tranny bracket
What will I need the Skid Plate for???
Also, the Edlebrock carb setup is only a stop gap until I get ready to pony up the $$$ the the Edelbrock bolt on fuel injection system.
Keep the reality check going. I appreciate it....
If you plan to stay on the street then its not necessary but if you plan to off-road the cruiser then a skidplate is a must.
With the new drive train the transfer case will be further rearward. You may also have skid plate to transfer case clearance problems depending on how high/low you mount the drive train so you may need to modify or lower the stock skidplate or better yet, make a new one.
You may have to relocate the battery? depending on how you set everything up, with that much HP, I'd think about 4 wheel discs, Make sure you set the engine far enough back to the firewall so the shifters clear the front heater but not so far back that you cant work on the distributor. Maybe change out the steering column for a newer model due to swapping from column shift to floor shift. That's all I can think of at the moment..
Plenty of folks have had fun getting the front driveshaft to clear the tranny pan. Fixes include bashing the pan in with a bmfh, going to small diameter custom flanges, and using smaller diameter tubes. So you should provide some leeway for shifting the drivetrain side to side before you "lock" it into final position.
My suggestion would be to purchase the FJ40 SBC install manuals from both Downey and Advance Adapters and read them cover to cover several times. Then ask more specific questions. Many, many of us have done this many, many different ways and are pleased to help but you gotta do some pretty exhaustive research on your own.
with the auto tranny get the motor as far forward as possible this will help several things: 1. rear driveshaft 2. tcase shifter 3. engine wieght farther forward(which helps traction offroad and radiant heat because the engine is farther from firewall)
