350 back to 4.3 conversion?
Hello all. It's my first time, be gentle. I have a 76 fj-40 with a chevy 350, stock 4 speed tranny, and stock t/case. Do a fair of amount of off roading but no crawling or anything major. Looking for advice to pick up some gas mileage and keep those hard earned greenbacks in pocket. At the same time engine needs rebuilt or replaced. Burns oil like Saddams retreating army.
1. Transfer case freshly rebuilt so that stays. Would also like to downgrade to a chevy 4.3.. Why the 4.3 you ask-- From what I have read the bellhousing, clutch etc can all be pulled from 350 and placed on the smaller engine? The 4.3 also gets better mileage, supposedly. Most importantly I can get it real, real cheap. My concern is what I am going to have to move to put in either a ranger OD or switch completely to a nv4500. It seems the ranger od is much less invasive and I might possibly be able to retain my current spacing without a whole hell of a lot of welding. I know the nv4500 is a better deal, less noise, much tighter, but it is also going to cost a lot more with the tranny and aa kit to switch everything over.
Any help or a parts list for either conversion would be awesome. Hope this wasn't too much for first timer.
Thanks.
I would go 283 but my buddy has a 4.3 rebuilt and ready to go. Can't beat 200 bucks for the engine. Will try to post some pics later today.
I'm not certain a 4.3 would net you and signifigant savings, particularly after all the bs putting in a new engine.
Why dont you just change to the 3.7 diffs? You can score FJ60 diffs for cheap, and put them in within a day.
Never thought of going the diff route. What kind of coin am I looking at?
I don't have experience with a 4.3 in a 40, but I do with a Vortec 4.3 in a 97 Astro. There is a difference between the older 4.3 and the Vortec 4.3, just not sure of all besides the heads are different. The Vortec has some real power. A friend had a late 70's Ford p.u. with the 400 big block. We had almost identical travel trailers. On Santiam Pass (Hy 20 here in OR), going up the grade from Suttle lake several miles to the summit, I could leave the 400 big block way behind with only about 260 cubes. Around town gas mileage for us has been around 15 and hwy has been around 18 (no towing). Not sure how to compare to a 40 because of gearing differences, but the Vortec version of the 4.3 is definately on my list for possible mods to my 40.
I am definitely leaning towards the 4.3 v.s. using my existing 350. It seems that the 4.3 with ranger od will be a very similar total length to what I have. The block on the 4.3 is about 5-6 inches shorter than the 350. I would gladly take 14-16 mpg if that is what the final mileage will be. Hope someone checks in that has done this damn conversion.
Quoting from the Advance Adaptors Toyota Land Cruiser Conversion Manual....
Chevy V6 Blocks: This can be either the 3.8 (229) or 4.3 V6. These engines are identical to the Chevy V-8 application with reference to the bellhousing, starter and flywheel. The oil pan has the same year differences like the Chevy V8. The 1996 & newer 4.3 blocks use an aluminum oil pan.
The motor mounts are also the same as the Chevy V8 with the exception of the location of the triangular bolt pattern in reference to the back of the block. The motor mount location on the V6 is approximately 4-1/2" closer to the backside of the block than on the V8.
You might want to pick up one of these manuals from Advance Adaptors. It's a really good resource for conversions.
http://www.advanceadapters.com/tlc.html
i know that butch (texican) did a real in-depth write up on this a while back...
a rebuild on the 350 will cost more than the 200 for the 4.3...i say go with the 4.3. there will be the added cost of the conversion/install and all that, but i still say go for it.
i used to drive an astro in high school (yeah, i was that cool) and it got a steady 20mpg and had a lot of power, regardless of the fact that it was in a van, ha ha.
good luck,
malphrus
I really dont think that you will save much on MPG, but if the engine is out then go with what you can afford. A 4.3 is a good engine for a 40. I would go with a nv4500 and forget the ranger overdrive. Lot less to go wrong.
If You get the new Advanced Adapters conversion manual you can check out my Cruiser on the cover.
I just had to throw that out there. :flipoff2:
I wouldn't want a 4.3 in my Cruiser but they are great motors and will probably be great for what you want. I wouldn't expect a big difference in mileage though.
After such shameless self promotion do I really have any choice but to buy the conversion manual? Hell, if mine never runs again at least I will hang the pic on the wall and dream of what could have been.
..Looking for advice to pick up some gas mileage and keep those hard earned greenbacks in pocket...
Not want you want to hear but you can buy one hell of a lot of gas for what any of the options you are considering will cost. Assuming you will have to buy the Ranger or NV new, it will take some +50,000 miles to break even, assuming your new combo will get an increase of 5MPG. From a cost savings standpoint it just doesn't add up to me...not for a toy. Now if you are getting this stuff free or even very cheap then it may change the payback. IIWY, I'd put a 305 SBC in it...they're often found very inexpensive and can give reasonable fuel economy over a 350. Cost $500-1000
I third the rubber overdrive or 3:70's. I have found and bought complete low-milage thrid members with 3:70 R&P's for $50-100 each. Cost: $350-700 for tires, $150-250 for thirds including new gaskets/seals.
Good questions....sorry I didn't give the answer you may be looking for.
Have you ever considered doing a diesel swap?
I used to run a '94 tbi'd 4.3 in my fj40 with an SM420, three speed case, and 4:11's with 33's. I thought it was a great motor. Not a powerhouse, and way less power than a vortech, but still better than a stock F or 2F. Not exactly sure what kind of mileage, but it was in the mid to upper teens.
you dton need an NV4500 or overdrive, though freeway will kill the mileage.
dont forget about the extra costs of new exhaust, harness, fuel pump, etc.
-Dustin
Thanks for all of the great input so far. Unfortunately, the engine must go. Compression is bad, so the bottom end needs some tlc and the top end isn't far behind. Like I mentioned up top, I have a rebuilt 4.3 ready to go for 2 bills so that is pretty much a done deal. The next question becomes how do I maintain the most "stock" setup from the back of the engine to my current drivetrain. If I convert to 4.3 then I can use my current bellhousing adapter and current tranny and transfer. The problem becomes the 4 or 5 inchest farther back the engine will sit from where it currently sits. Thats where the od unit would come in. It would take up the space currently occupied by the back of the 350. Don't know if the stock drive shafts will accomodate the change(not using and od and sticking with what I have) without mods. The rear shaft would have to be longer and the front shorter, correct? If the shafts can be altered relatively cheap the only thing that has to be done is move the transfer case crossmember forward, correct? With that said I might very well consider the 3.70's. How much of an impact will they make on off road capability.
Oh and yes have considered diesel, how difficult is the swap?
A diesel swap will be much much much much more expensive. First you need the engine, and any decent one will cost you 2 to 3 grand. then you need the wiring harness, relays and solenoids. Then a different alternator with vacuum pump. Things like PS pump and A/C compressor will not be the same. The brake booster is different...you get the idea.
If you get a rusted out canadian truck with a good drivetrain you might be able to get away with 5 grand, if you do all the work yourself.
Professional diesel conversions start at 15 grand.
j
if you put the 4.3 in, you dont need to move any of the other drive train components. You'll just have more space between the radiator and the front of the motor. You can keep your bellhousing, tranny, tcase, and drive line components unless youre dying to spend more money - in which case I would suggest just spending 1200 and get a replacement block. But going to the 4.3 isnt going to be cheap either. You still need to buy and install the new motormounts, get exhaust, a new chip, a wire harness unless you are going to weed through it yourself. If its not a TBI, then add another $100 for a high pressure fuel pump.
[edit] oh... and youre probably going to need to remove the stock steering box to clear the manifolds [/edit ]
-Dustin
-Dustin
