305'S And Gears?
Alpharetta GA
Just still trying to decide what lift to go with and tires. I started out dead set on J-springs and 315's with 4.88's, but for money reasons and being able to fit it in the garage I was thinking the medium springs and 305's and hopefully wouldn't need to regear at that point. Anyone have any input on this one, any pictures of rigs with this set up or 285's? Thanks as always.
You don't have to regear with 35s or any smaller tire size...When you move to 37s that's when you need to start looking at a regear. I am running stock gears with 35s right now and it doesn't bother me a bit. Check out the FAQ for more info because Romer has put together an encyclopedia on this subject
SJ
Most folks don't regear until they get to 35's--even then there are plenty of folks running 35's on stock 4.10 gears with few complaints.
The elevations you usually drive at can factor into the effects of larger tires with stock gearing too.
I noticed a very minor change going from 285's to heavy 295's with stock gears. Now I just run with the PWR button on. Off road there is no negative effect at all.
I'm running my 295's with the OME 2.5" heavy lift. I measure 2.5" of lift up front, and 3.5" in back. There are photos in the link to my ROTW in my signature below.
Hayes
I have J's 35's 4.88's and fit into the garage with room to spare. Course I have some accessories that weigh me down a bit.
Hayes, awesome article. Thanks for the info. I live in Atl area so the air isn't too thin down here. How does the vehicle ride compared to stock and how is the power with those 295's(they look perfect for that amount of lift) compared to stock. Thanks!:cheers:
I had 285's (cheap brand AT tire) before the 295 Nittos, ran them pre- and post- lift. In addition to being a solid 33 inches, the 295 Terra Grapplers are heavy. I did notice a little bit of sluggishness starting off the line (speaking relatively here), but nothing worth worrying about. Running with PWR button on lets the engine rev higher before shifting, which largely deals with the change. I haven't noticed any hit in fuel economy since using the PWR switch, either (higher rpms = less gas pedal, I assume).
As for overall ride comparison, the Terra Grapplers are such a better tire on and off road, I couldn't really speak to the differences caused by size.
295/75R16 Terra Grapplers ARE an excellent size for the OME 2.5" lifts. No fit or rubbing issues whatsoever, and they DO look nice.
Hayes
