305 vs. 285
Washington, MO
I have been looking for side profile photo's of 305/70/16 vs. 285/75/16 tires on factory rims. I'm having problems deciding between the 2. I've seen in person the 285's on factory rims, but I can't find the right photo of the 305 (to compare). I would also like to know what anyone thinks about 305's on 10" rims.
Most 305 70 16's are basically a 32.5 X 12.3 inch tire converted to non metric terms. The 285 is a 33 X 11.5 inch tire. Both sizes can be slightly larger or smaller depending on the brand.
If you go off road much you would stand a good chance of popping a bead with 305's on 10 inch rims when aired down.
I would stick with 285's and save the money you would spend on rims for something like a lift, shocks, whatever. Good luck.
They will look virtually identical from a side profile, as the sidewall heght is virtually the same, the difference is in the tread width.
Got both - BFG muds, on 2 different vehicles. Both on 16 x 8s. Theres bugger all in it, but the 305 is a bees dick taller. IMHO get the 285s on 8 inch rims, if your after a 33 incher. Cheaper, more common, and wont rub your rear inner guards as much.
FWIW, on factory rims, they look identical.
Matt
Thanks for the tire info. I'll probably go with the 285's.
The next dilemma is 2", 3" or 4" lift . Man-a-Free, OME or Slee.
I'm a fireman in Washington, MO. Consequently, I have a tendency to drive a little agressive on the road also. (depending on the nature of the call)
I would like to keep the road manners in check. What I don't want is street handling like I had on my Ford FX-4 packaged F-150. I got rid of it because, it would squeal the tires and feel out of control going around 30 MPH turns, it felt like the tires were out of air.(no they weren't) Off-road it handled "OK". Kind of like taking my dad's town car out to check the fences.
I'm aiming for MOAB next year, I don't want to tear the crap out of my LC, but I'm looking forward to going off-road without having to spend 3 hours cleaning the mud from the undercarriage.
I know that most of the LC aftermarket suspensions claim that road manners are maintained or improved but they were "designed" for off-road driving. At what height does on-road handling become sketchy while agressively driving.
That depends a lot on the vehicle and the supporting mods you do to it.
Anything past 2.5" and you start looking at a new front drive shaft, adjustable panhard bars, agressive castor correction... all to make it drive like a factory rig again.
The firmer lift springs do wonders for the body roll of the 80 series (so I'm told!) but don't go so tall that you need all that extra stuff.
Most recommend the Bridgestone REVO A/T for mainly on road with some off-road. If it is mainly an offroad rig get the MTR's or similar tread type.
I can take sweeping corners at 60mph+ with mine and they don't squeal. The truck handles very well for having 33's and much better than my '84 FJ60 on new suspension/tires/lift (coil over vs. leaf springs). I have no complaints about this truck at all. I did notice longer stopping distances with the 33's as the main draw back and little loss of power. With 33's you don't need to swap to deeper gears in the pumpkins. With anything larger you should.
I commute in mine and if I'm soft on the gas pedal under accelleration and cruise under 70mph (indicated; however in reality about 74mph) I can get hig 14's low 15's.
wfd175 said:
Doc,
What do you think of the destination M/T's. How are they holding up?
The world's greatest tire. Ever. Hands down.
Okay, they could be better in snow/ice.
As they are wearing in they are getting a tad bit louder, and hum a bit on the interstates... but for a true M/T they kick butt. I love the higher load range, which lends itself to better handling and towing. I don't do much 'muddin', but they do clean out nicely in the muck that I sometimes find myself in. Are they DD tires? No- not really. In all reality I would most likely be better seved by revo's or an A/T. The Firestones will hurt your gas milage because of the greater wind resistance in the tread, they hum as they wear in, and sound like swampers when your windows are down...
But they are so good at what they do. I've never been let down by them.
Resurrect
I would like to resurrect this thread and see if anymore opinions come in...I have 285/75R16 Nitto TG right now and am ready for a replacement...i have a lead on a really good price for the Cooper STT and up until a last week was set on getting 285's again but a buddy of mine said if you went with something a little bit wider (305/70R16) it would keep your rims a tad farther away from the rocks. Does anyone see a reason not to get the 305's? They are like $10 more/tire so price is not an issue...thoughts :confused:
Thanks
Barrypt5
They're wider so you'll have more chance of rubbing where you didn't rub with the 285's. 285's are also more common and in turn easier to find.
why not 295/75/16s? the hankook MTs are measured at 33.6 by 11.6
toyo makes a 295/70/17 which comes out to 33.5 by 11.9
If you like the TG's you could go to the 295/75/16 @ 33.27 by 11.73. I don't rub anywhere when twisted up (stock). If I hit a good sized bump and it pushes the axle straight up, I get a little rub from the shoulder of the tire and the lip of the wheel well.
Nak
i put the hankook mt's on mine, in the 295/75 16 variety. and so far am very impressed. they handle well on the road with no more noise than my heeps bfg at's. and the little amount of offroad they have seen so far they worked flawlessly! they haven't rubbed anywhere at all on my rig. i have the ome 2.5 med kit on. good luck on your decision. you probably cant go too wrong with most of the recomendations you have here.
