Has anyone installed a 30 inch LED light bar on a sahara bumper? I have one and it is overall 32 inches wide. I am wondering if anyone mounted one on the bumper beneath the hoop and if so what type of mount did they use.
Is it the light bar with the included mounting pedestals that measures 32"? I wonder if having the u-shaped cradle mounts would allow you to squeeze it in? If it were me, i'd remove the bull bar portion and run it sort of like a front Slee.
. I could mount the light above the top of the hoop, any comments on that? Has anyone had to cut the rubber on a Sahara bar? I could also mount the cradle on the front of the bumper but thatt would seem to endanger the light since it wold be the first item to strike anything.FOPLawyer said:Here is what I am thinking, if I mount 2 one inch risers on either side of the winch access plate, then mount the cradle with x-long bolts my light qwill sit one inch higher than BBQs. This will prevent the need to cut the rubber as it is 1 inch tall. I am thinking I can make the risers out of Trex material I have lying around (rot proof and paintable and worked with standard wood working tools). This way the cradle will over lap the rubber and the bolts can extend down below the bumper shell for secure attachment.
Any obvious problems?
