3-speed TC gears in a 4-speed TC
Central, Utah
Am switching to an SM-465 transmission with 3-speed TC gears. I want to know if I can put the 3-speed gears and such in the 4-speed case being the stronger case. Or should I just put my 4-speed TC parts on the 3-speed case?
Thanks.
E
Why not run the 3 speed case and if you grenade it then you can swap. If you don't grenade it then you've saved a ton of work!
I thought of that too but I hate being towed in. I'm hoping I never need to fix anything worse than a birf out in the rocks. Just trying to do the best possible job I can since I have both 3 and 4 speed tranny/t-cases. If it's a drop in to put the 3spd gears in the 4spd case then it should be worth my time. That is if the 4spd case is enough of an improvement to make it worthwhile.
E
I believe if it's a transitional t-case (early 74,... possibly 73 as well), you can just put the input gear in your 4-speed t-case.
Granted, I'm definitely not 100% sure of which t-cases let you do this,... but I put the 10 spline input gear from an early '74 t-case into my late '74 (16 spline) t-case,... it fit perfectly, + saved me a bunch of time.
Hope this helps
WILL
There's a great article in the tech section on T cases. The 3 speed and the 4 speed have different internal dimensions so you'll have to shim to make the swap work.
what year is the 3-speed case? My 72 has yet to break with an Amway t-case saver on it...and I'm NOT easy on my rig either....
Woody - it's a '69 3spd t-case. Will it survive rockcrawling?
76 - I'm pretty sure I read everything in tech but didn't find any mention of this swap.
How hard is it to shim up? Is that the only mod required?
E
I removed my 69 case after 3 hard years and installed a 72 one, since I had similar concerns. I never did break the 69....honestly, if you A> run the t-case saver, and B> a GOOOOD skid plate that protects the entire t-case from any shock hits while crawling, I wouldn't expect any problems.
However, if you have the parts to strengthen, or to go with a newer case, I'd do it.
[quote author=hammerhead link=board=1;threadid=7849;start=msg65975#msg65975 date=1069386288]
Thanks.
E
[/quote]
Putting the 3spd gears into the 4spd case is pretty easy. I did it last spring also using the 4spd output shaft and the 4spd nose cone! You just need to get the shims to shim up the idler cluster, since the 3psd gear set is narrow!
http://board.marlincrawler.com/index.php?board=16;action=display;threadid=1189
