Wanted 3 speed floor shift transmission
Status
Not open for further replies.
Cedar Park,TX
Looking for a good three speed floor shift transmission in or near the Austin, TX area as well as the floor cover. I am looking to convert from a column shift to a floor shift model. Let me know what you have.
I have a Downey Offroad top plate shifter for the 3 speed on a 3 speed trans in South Dakota but it will be 3 weeks before I’m back home. Let me know if you don’t find one by then.
How is a "Downey Offroad top plate shifter" different than a factory shifter? I am not real familiar with these vehicles. I am learning.
The top plate on the transmission converts it to a top shift and it was a aftermarket parts produced by @Downey offroad back in the day. I could very well be incorrect but I’m not sure that Toyota had a top shift option with the 3 speed trans. Just the column shift.
Is there anything wrong with your current transmission? I would sell you just the shifter or both.
@Redgrrr , there was a factory floorshift later on in Toyota production, starting as OPT in 1971.
That said, if all that’s wrong with your trans is sloppy linkage you want to get rid of, you can swap the covers over like @Redgrrr indicated.
If you want a rebuilt 3speed, I have a couple in Burbank. Floorshift too.
I was thinking the Downey top plate didn't have the reverse switch attached, where the OEM 71-early74 had the reverse switch attached to the housing.
X2
Jim posted not long ago because of the cost you add the boss for a reverse light switch Downey covers didn't have one. Pretty sure Toyota made them minus the reverse light switch as well. While not a option offered here until later countries like Australia had the floor shift standard in the sixties.
X3, I believe ALL of the factory floor shifter plates had the reverse light switch mounting boss, and some Downey's had the boss, but then we eliminated it since the cost to produce with boss became too expensive (required a core box that doubled the cost).
The 3 speed shift okay from 1 >2, and 2>3. Going from 2>1 does not work. Should I have double clutching? Otherwise it shifts fine. I would prefer a Toyota part. It is going into a 71.
If the only symptom is going from a synchronized gear to a non-synchronized gear, chances are it's just sloppy linkage, because that's not a smooth shift EVER. So you can tighten up what you have, or buy a used shifter assembly. MANY available.
Thank you 65swb45. I will check the linkages. Gtk that it is not a smooth shift. The last one I drove was a 79 with a 4 speed and it shifted fine. This is very different.
More info, Downey and Advance Adapters had the boss in the top plate but not tapped for the PTO shifter pivot pin. Also AA did not have a boss or even tapped for a reverse switch. Pictured on left is a Downey, middle Factory, right NOS AA. With AA you swapped your shifter plate from your stock column shift cover. In 1975 I had a 1965 FJ40, put on Man-A-Fre 4 to 1 header and had to remove column shift linkage and get a floorshift for clearance. Top covers and shift canes are for sale. John
^^^^ With Downey's you also had to transfer your shifter plate from the stock top cover to the Downey cover- - -easy deal.
I learned something new today! I never knew this before.
I have one in Houston. You think you can come get it I'll give it to you for free.
It's from 74 with a one-piece transfer case. I do not have the flywheel and I'm not sure if I still have the clutch Fork.
Pm me for details
Thanks for your order John.:)
Status
