Hello everyone. I was thinking this, there are multiple companies which make 3 or 4 gear tranfercases for low range. in FZJ80, transfer case has 2 gears. 4 hi, where all 4 wheels are driven (via some sort of limited slip) and 4 lo, where all 4 wheels are locked via center dif, and some models have lockers. Now, the 3 gear transfercases have 2 4 lo gears, but are there any which have 2 4hi? As in selectable between 1:1 and for example 1: 1.15? ?? This would be pretty cool, as you can easily switch out tires based on your needs. If for example towing or going on long camping trip with minor off roading, running mt tires 37-40 is not really efficient... or comfortable. For those conditions having a set of 33 AT or even highway tires. and if plan to go trail/crawling, switch out to set of say 38s, and put differential to 1:1.15, and you are set, no need to regear? makes sense? any such thing on the market?
