NorCalBorn
**If anyone has an X-Tra Cab P/U of the same era LMK via pm if I can see if you face the same issue(s) discussed in this thread so I can consolidate a possible write-up bit.**
I took a look at my rain gutters tonight, purely by chance as I was in the process of removing my roof rack system to check the seals, etc and I found out that after only 2 years since I last base-lined it I now had a ton of pine needles, dirt, pond-scummy-looking-muck, and bottle-brush leaves and needles trapped in the rear drain section clogging it all up and some rust starting to form. I went ahead and cleaned it out briefly and tomorrow I'll go through the way I did a couple of years ago. Here's some pics post pressure washer blast and a quick seal coat on one small rust section. I'll post more as well as the stuff I used tomorrow when I get more into the job.
