- Thread starter
- #21
Started finally last night, would start this morning.
Hello Guys,
Last night we used a little but of starting Fluid during cranking and it finally started, huffing and puffing and having a lot of hiccups. We kept it running for about 5 Min before we had to shut it down. It settled into idle but would stutter when throttle would be applied.
After about 40 Min we tried to start it again! No Luck. Used the fluid again and it started with a little stutter. This time we kept it running and the stuttering finished when we would give it throttle. Seemed like air had been purged from the system. We waited for the temp needle to rise and took it for a drive around the block.
Every thing was nice and smooth, engine was accelarating as it should, turbo spooled up ( green light came on when driving), came back and checked for any leaks. kept an eye on the temp and oil pressure. With the old head it would be overheating by now. Not the case this time.
No noticeable smoke as well. We parked it in the garage and called it a night.
This morning I wanted to purge the coolant system and circulate the coolant throughout the system( heater core etc) using the method on the AllHead site. Tried to start it! No luck. Cranking doesnot work. It was 10-12'C in the Garage.
1. Air is leaking back into the fuel system.
I donot have access to an air compressor, so i cannot use the pressure the return line method.
The vehicle used to start fine before i pulled the head. I didnot touch the fuel pump at all. The fuel system connections that i took apart were.
1 Injector lines,
2 injectors,
3 fuel pipe assembly that runs among the injectors and the rubber pipe that attaches the fuel pipe assembly to the fuel pump.
http://pg.photos.yahoo.com/ph/rummat...cd.jpg&.src=ph
you can see the rubber pipe coming out of the left most injector to the pump.
During this project i had to remove the filter bracket the put the filter on its side to create room. the pipe conections to and from the filter were not loosened, just the whole filter assembly was put aside.
What is your diagnosis guys, and where should i start.
Thank you,
Ali.
Hello Guys,
1 Injector lines,
2 injectors,
Thank you,
Ali.
