Hi all,
I have a problem with my injector pump, the fuel control arm (gives extra fuel on startup and shuts down the fuel on turn off - controlled by the EDIC motor) has lost its 'spring' and isnt letting the engine turn off, or start properly.
As the arm runs into the engine behind the diaphragm it has been advised that I replace that too. I have pulled apart a spare (dead) injector pump I have out the back as practice, as I plan on leaving the current pump in for the work.
The red circle shows the spring, and where it clips to the arm,
And the arm
And a second pic.
This is the first time I have ever opened an injector pump, and while it was an easy procedure on the bench I think it will be fairly tricky when its still in the car.
My questions are, has anyone experienced this before? is the spring likely to have fallen off? OR shattered into a million pieces?
Is there anything else I can expect to find when I get in there?
Im going to give it a go this afternoon, so seriously any advice appreciated!
And the arm
And a second pic.
