Resurrecting this old thread. I'm considering the various engine options for my '71 FJ40 build. Here's what I have to work with:
- '71 FJ40 with a running '76 2F with unknown history, including mileage. It has a mini-truck power steering upgrade with an '84 Tercel pump mounted on the smog pump bracket (down low on DS of block). Air injection system removed. '71 FJ40 engine accessories, including rebuilt carburetor with added vacuum advance port. Have parts to add oil cooler and convert to FJ60 electronic ignition. It will have a later H41 from an '84 HJ47 and a drum parking brake split transfer case from an '85 BJ45. 4:11 differentials.
- Running '76 2F with ~66,000 original miles. It has the same power steering conversion as above. Air injection system removed. '76 FJ40 engine accessories, including rebuilt carburetor with stock vacuum advance port. It has oil cooler and FJ60 electronic ignition upgrades.
- Running '84 2F with ~182,000 original miles. All stock with rebuilt carburetor.
- Complete '91 3FE long block with exception of head bolts, in need of rebuild due to spun bearing. 3FE cylinder head checked out good. I'd need an ECU, engine wiring harness, electronic fuel pump, intake manifold, air plenum, exhaust manifolds, etc. Already have some spares accumulated for my '86 FJ60 with a 3FE.
I'm leaning towards a 2FE using the low-mileage short block from my '76 FJ40 and the cylinder head from the '91 3FE. I wanted to confirm the flexibility by being able to use any of the 2F short blocks I have available. Any feedback would be appreciated.
