We weren't questioning you and really appreciate the help. We just thought that if they were indexed they couldn't be installed wrong. Obviously we were wrong on that one. Just trying to get a good grasp on the oil flow and what could effect it, and if putting main or rod bearings in wrong would have any effect on the top end. I am still confused on which main the oil goes through to get to the cam bearing and then the head. Page 24 of Haynes, secsion 14 says oil goes through #3 main before going to cam and head; but page 34, section 35 says bearings for mains 1 and 4 have oil holes? Don't they all have holes for oil to flow through? I'm wondering if one or more main bearings are in wrong, but at least the one supplying the head.
We pulled the rocker assembly off and cranked the motor. No oil came up out of hole in #4 tower. However, if we pour oil into the hole, it will drain back down VERY slowly. This would lead me to believe that the headgasket is on correctly. If it was not, the oil wouldn't drain back at all would it? (Again, my lack of knowledge of the engine oiling system coming out) Also, the rockers, pushrods, and valves all looked to be in really good condition with no visible wear that seems excessive, so I don't think it's been running long without oil, probably just the few days I have been driving it.
If it's not the headgasket, what are ya'lls thoughts? Main bearing in wrong? Cam bearing (which he didn't touch) moved, if thats possible? Just gunk in the lines? If gunk, whats the best way to get it out? If main bearings, should I just drop the pan and pull off #3 (if thats the one going to the head) and fix if wrong, then button up and run it, or pull motor back out and put in all new bearings and cam bearings to be safe?
Thanks for all the help everyone has given.
