I need to purchase a valve cover for the 75 2F I'm sending out for rebuild/upgrade. I am seeing listings for them with date ranges for compatibility... So a valve cover from a 80 2F won't fit a 78???
It looks like the OP has purchased an 81-87 VC.
To fit the tall 75 rockerstands & hardware, as well as the air cleaner, a 75-80 VC is needed.
FWIW:
Below is VC with the screw in cap that @FJ40Jim suggest for the 2F's that require the taller covers.
Note, I had an '86 2F rebuilt. I installed the taller rocker studs for the taller VC so my '77 carb and air cleaner assembly aligned.
Thanks GA. So it sounds like the 80-87 vc I just bought will not fit my application (78 2f). Is it possible to modify the 78 head to fit under the vc? I know that sounds a bit backwards, but I am having my builder go through the block and the head anyways, so I am curious before I beg for a return on the vc I just got off ebay.
Seems like I read not too long ago about someone using a short VC on an earlier 2F engine and had no issues. However, they were not using the same type of carb & air cleaner as I have. May want to search for that thread before you send that VC back....
It was actually a 1F engine. Take a look at this thread: 2F Aluminum Valve Cover on a 1F engine
What was the final outcome on the valve cover?Thanks! It SEEMS like that post suggests that internal rocker arm clearance isn't an issue if I choose to do this. I asked the question on the post just to be sure. These things are going for 120+ all cleaned up and painted/coated, so I really don't want to do the whole trial and error approach on this.
I have both valve covers. I powder coated the original now it has a very very slight warp in it.
Looks like your making progress Tony![]()
Do you have any idea where I can find a valve cover like that or at least an aluminum one that looks just as good for a 1976 FJ 55
