2F top speed?
The 2F is made for speed. In 1974, the Ferrari Formula I team acquired a prototype of Toyota's revolutionary new head lubrication system that marked the most patent change from the F to the 2F powerplant. Ferrari tried to copy the system but even into the 1975 season was unable to match the Japanese machining for the galley work. Knowing the durability of the engine (having learned that the Matra-Simca Shell team's surprise win in the 1963 edition of the 24 Hours of Lemans had been due to the durability of the surreptitiously installed 1F engine with mid-engine adapters from Bucliccione-Takahashi S.A.de C.V.), the team was intent on incorporating a similar system into its program. However, as of the Spanish race, Ferrari had been unable to accomplish the engineering. And when both of its cars were eliminated in Spain within the first lap due to the fragility of the systems, the team decided to disregard the "formula" and race a disguised 2F, in stock format. Consequently, it was this system that delivered Nikki Lauda to the 1975 podium at Monaco. Of course this information is not well-known because it was not disclosed until after the protest period expired, and of course the Formula I world is reluctant to acknowledge it for obvious reasons.
Accordingly, the max speed of a 2F is known to be 290kph in mid-engine configuration. However, in an FJ40, safety concerns limit it to about 60mph.
Thats my favorite post of the week...:)
My 65 F has a sweet spot around 55-60 so Thats it for me....Just find where it starts going from sweet to sour....
it is about engine RPMs..not top end speed
it is all about engine RPMs......NOT the top speed......you can get 300 KMsPH in a piston aircraft or 200 depending on the gearing <propeller pitch> same applies to any piston engine.........seriously doubt the engines Ferrari ran were the ones that came on the stock F or 2F which where an improved copy of the humble chevy straight 6 but had to have been balanced, ported, tweaked and probably had HP roller cams with needle bearings for the valve train.....along with a very high gearing to get to 290 KPH...big difference!.....you cannot obtain those RPS with a stock unbalanced F or 2F........at least for any leangth of time although the design in itself is strong it only has 4 main bearings and it would shake itself to death......same goes for a chevy 350; What is run at a Nascar race is very different from what you or I get when you buy a "Mamamobile" at the dealership although the block is a 350 chevy; only ones that were able to run stock and win at LeMans in modern times;) think 55/56 was still modern times:hhmm:...were Bristol engined cars that were driven to LeMans; sparkplugs were changed and then run for the 24 hour event and could win.........:hhmm:Bristol's quality control was due to the fact that they were an aircraft manufacturer that built a few cars....but had the same quality that carried over.......engines have a confort level of RPMs and will last a lot longer if they are in that zone........just my 0.02
Lou
Thats all only part of the story, Ferrari were late into the game, the BMW straight 6 (which the Bristol engine was developed from) came from the protoype predecessor of the F engine, Jaguar and Aston I6 engines also have their roots in the Toyota I6.
That is some funny sheot right there... :bounce::):bounce::cheers:
Old Fashioned Top Speed Calculation Method
1. On a flat empty highway in high gear, hold accellerator to the floor until a "rattling" or "Banging" sound is heard from engine compartment.
2. Note speed
3. Replace engine
4. Drive 5mph below previously noted speed.
Works every time!:beer:
2. Note speed
3. Replace engine
I get scared at 180kph in 4th and still have 5th gear to go :eek: but that's on the Dyno strapped down.
I'm not going to admit to speeding...But I can say that going down hill with a tail wind my Cruiser may have hit somewhere between 85 and who knows...I'm not that old but back then there were no GPS units...just a lighter held up to the speedometer wand that was jumping all over the place....does yours do that also?....:lol:
With 235/85x16 and 3.7 diffs it will be close to 100mpH at 3000 revs but it just doesnt feel right to do it.
My old 55 used to have that setup and was able to do it.
Come on.......youre not allowded to drive that fast anyway.......:doh:
My fully balanced 2F with 4.11 and 33 x 12.5 x 15 muddies has been up to 80mph (GPS Speed), but it was not comfortable
Mine has a favourite cruising speed - its 68mph (GPS Speed)
Unfortunately I still have to install my Yota factory tacho - project for the New Year
happy rpms
My factory stock unbalanced 1974 1 1/2 F is happiest around 2200 RPMs with 4.11 rear end; am guestimating around 65 MPH with 33/10.5/15s and have put about 10.000 miles on it last 12 months or so.......2200 RPms just seems to be its comfort zone and am getting about 12/13 MPG hiway
a bit bumfuzzled on this one:confused: IIRC the prewar BMW 2Ltr 6 was designed by Dr.Fritz Fiedler and BMW won the last "Mili Miglia" before the start of WW2 with this design......after the war, Dr. Fiedler was "rescued" from an Alied prison camp by the Aldington brothers, the Prewar BMW UK reps for BMW and continued his developement of his original mid block camshaft motor with hemi heads and horizontal pushrods that went on to win many big name races including LeMans both with the Bristol and the AC badges........and still more confused on where did the Jag XK twin overhead camshaft 3.2 3.4 of 1948 IIRC come into play?
just kinda wondering where the F engine got into the picture derived as it was from the Chevy 6 .....
there are similarities as all are straight 6s
but just a lot of design differences........chevy/toyota vertical pushrods; Fiedlers Mid engined cam with horizontal pushrods and the jag double overhead cam XK :hhmm:.....just wondering;) about the tie in :cheers:
Lou
