Got a 77 2F that I'm putting in my 62 FJ40 and it has no oil going to the top end. This is a fresh rebuild. Installed the engine yesterday and primed the system prior to install of the dizzy and I am not getting a drop of oil to the rockers, getting good pressure to the lower end. Started back tracking on what could be the culprit, I took off the rockers and tried to prime it again, nothing.
Next I took off the head to check to make sure I didn't have a moment and put the head gasket on wrong. It was on correctly.
With the head off I primed it again to see if any oil came up that far, no dice. I can look down the oil hole and see a pool of oil, but nothing is making it up to the top.
Only thing I can think of that would keep oil from coming up is the cam bearings. I'm going to be livid if the machine shop put in the wrong bearings, or didn't get them installed correctly after they had it for a month! Anyone have any suggestions before I take this engine out? Not looking forward to this, it is a huge PITA to muscle a 2F in by yourself.
