I didn't search also usually not in 60 tech so here is the ?. picking up a 85 60 series, PO says the compression is good will check next weekend, has a newer head bought from SOR, keeps fouling the 4th plug. could the headgasket be put in wrong and the oil hole isn't lined up?? cause this problem. also rear half of motor on distributor side has a nice covering of motor oil.
