2f carb Main Nozzle size
Dover, DE
Jan 1985 Carb based on stamp and SOR Pics.
On main nozzle sizes, (venturi assembly on some paper work),
Which side does the small hole nozzle go, one on left in pic? I neglected to notice the difference on a rebuild. My guess is primary...:meh:
Semi related threads where FJ40Jim weighs in
Distinguishing small venturis on Aisin carb
Carbuerator emulsification modification
Boosters: The primary booster has a larger air jet and smaller discharge nozzle. The number cast on the booster is only a mold number, doesn't mean anything.
I also failed to mark a pair of boosters. Using a rubber tipped air blow gun, I was able to hear which booster nozzle flowed more air. I put the higher flowing nozzle on the secondary side:hillbilly:
Thanks for those links. Must have missed them in the half dozen searches I did....:D
I going with the small on primary. Easy enough to switch if needed.
