Plug what? If you are talking about the hose coming off of the AAP, it can connect to manifold vacuum which may be the lowest of the three uncapped brass tubes at the base of the carb.
AAP is auxiliary accelerator pump. It works on vacuum to assist the mechanical accelerator pump to give it a little extra squirt of fuel when you put the pedal to the metal and have a wide open throttle. Try hooking it up to the lowest port.
