2F carb idle issue again
Vancouver island
I've rebuilt 2 carbs and they both behave the same. They will not idle properly until Ipush on the secondary lever for a second then everything clears up until I restart the engine. I pull the choke ,start the engine and have to leave the choke on about 2/3 and pull the throttle cable,then get out of the truck open hood and push the secondary lever on the left forward until it bottoms, it stutters ,revs a bit then ramps up. I push in the throttle and choke and it idles beautifully until I restart the engine. What possible connection is the secondary to the idle? I've sprayed everything loose. It will idle at 600 rpm all day like this until I srestart,then 2/3 choke and hand throttle. Who's the carb guy?
The secondary has nothing to do with the idle circuit by design. The fact that it has an effect indicates that the idle circuit isn’tworking, either because of a manifold vacuum leak or a lack of idle fuel. The fact that two different carbs behave the same way points to a vacuum leak as more likely.
BTW, I presume you are talking about a 72-74 vintage carb, but it is always best to give this information.
It is a 77. seriously there is only the brake booster and PVC valve on this unit,which have both been disconnected. The intake and carb I checked with propane.no issues. the only thing that works is bottoming the secondary lever on the left side,1/8 " of total travel when idling, it revs a bit then idles perfectly,otherwise it takes 2/3 choke and hand throttle to keep it running. driving it 's a hit or miss at stop signs.
Loctite. If you have vacuum gauge, hook it up to a port on the intake manifold, get your engine well warmed up and post up what your numbers are. Should be close to 19 at idle and no jumping needle.
If you don’t have one, you should get one. They are handy. One step further would be get a long hose, run it in tge cab, so you can watch it while driving.
Idle control solenoid?
Too much idle speed screw?
Incorrect reassembly of throttle linkage? Pics help. So does use vacuum values...
Thanks, I agree vacuum guages really work.In this instance the engine will idle perfectly once I do the secondary thing,It makes no sense to me. I have tried staring without using the choke, makes no difference. I have to push the secondary lever forward 1/8 to bottom and then it idles fine for hours,otherwise it won't idle unless the choke and throttle is on.
It works because it is pulling fuel from the secondary transition slot, but the secondary butterfly is supposed to be completely closed at idle. Either there is no idle fuel on both carbs (solenoid not working, or passage plugged) or there is a vacuum leak.
I have disconnected the idle solenoid and blew out the ports. solenoid works when I hard wire. I can idle it down to 600 RPM after the dance, otherwise choke it
Pin_head, should I check the 2nd slow jet. If it's idling through the secondary how come I can adjust the idle up and down to 600 rpm on the primary. It can be adjusted down to stalling.
Unfortunately, what you are doing isn’t working, so you need to do something else. It is unlikely that both carbs would have the same idle problem, so I would look more carefully for leaks. It is hard to reach the underside of the manifold where the gasket usually leaks and there can be cracks in the manifold that will leak. If that doesn’t appeal to you I would rebuild one of the carbs more carefully and verify that the idle passages are clear with nylon monofilament line and carb spray.
You can adjust the “idle speed” to be nearly anything you want with the idle speed screw, but it isn’t idling. It is running off the main nozzle.
What pin head said. I had leaks below my intake manifold, fixed that but still had same problems you described. Solution? Sent carb out to @FJ40Jim and it purrs!
Worth EVERY penny FWIW
It 's crazily infuriating that it will idle perfectly then not, just by turning the engine on and off and poking the lever once.
I'll recheck with a vacuum gauge tomorrow and look to see if it's drawing from the main nozzle. I appreciate the help guys,and will keep you posted. should the vacuum tube go on the small port of the carb that goes to the choke breaker diaphram
Just back your idle speed screw out all the way then back in till it’s about a half turn past just touching. Turn your mix screw in to bottom and back out 4 turns. Make sure idle solenoid is working and set idle with lean drop. It won’t matter if it’s only chugging at 550... then set your idle speed. If it won’t chug down at 4-500 rpm with the speed screw backed off, you have an intake leak or a lack of fuel. I can back the screw out to about 3-400 rpm. You think it’s gunna die, maybe it does, give it a bit more speed, but not too much... make it pull the fuel; don’t dump it in...
Keep this in mind as well. At some point you could just unhook the linkage in case it is slightly holding the primary butterfly open causing the idle circuit to be nullified and allowing fuel to be pulled from primary nozzle.
Another quick test is unplug idle solenoid power wire while rig is idling. Engine should die if it is truley running of idle circuit.
You probably know this too, just a reminder....at idle shine flashlight down primary bore, if you can see fuel spray your idle circuit isn’t being given the opportunity to work it’s magic. E.g. primary butterfly cracked open, not enough suction due to valves out of adjustment or vac leak, or clogged idle passage.
interesting update is fuel bowl drained through secondary port just at butterfly when engine was turned off. I missed something on rebuild but can't see how it can drain according to schematic. Idle solenoid works,quit on disconnect. secondary will weep on idle, but drains bowl sometimes on shut down. no aap on this model. No black smoke.plugs are white, too lean. haven't found my vacuum gauge. The primary is drawing through the idle circuit and not the primary nozzle. It appears engine won't idle rich enough with just the primary and when I blip the secondary lever it causes a flow that continues to enrich the idle through a secondary idle circuit. have to shut off choke and throttle,idles perfectly. If I set primary idle up,sometime during the trip the secondary idle decides to function and revs my idle up .Why is there an idle circuit and port on the secondary with a transition port above it? That's what's causing the issue, but why and how is it weeping in? fuel level does fluctuate but stays pretty close to dot.
There is no idle circuit on the secondary. Just the transition slot above the throttle plate to momentarily enrich the flow as the plate opens until the vacuum reaches the main nozzle and starts pulling fuel out. The fuel is metered by the slow jet and you have the same transition slot on the primary, but the primary also has the idle fuel port below the throttle plate.
If fuel seeps out when it sits, it is most likely creeping out by surface tension. Here in CA, this is caused by oxygenated fuel. It could also siphon out, but there is an air vent at the top to prevent this. The air vent would have to be plugged for it to siphon out.
