Build #27 red and white 55, full body restoration.
Back at it. Working through these remaining rusted areas. Getting close to assembly, and that is exciting.
I cut this from one piece, but its difficult to weld this without having gaps because its long and has a crazy shape. I cut it with a shear where my finger is pointing and I will weld both pieces on first, then butt weld that small seam without a grinder gap. Im not going to bend the lower line yet either. I will wait until its welded together, then it will be a perfect bend.
I welded the top side then I flipped it over and used silicon bronze to go over the seam, filling any low spots. I butt weld everything with my tig welder but it leaves low spots or little pits from the metal melting together, so sometimes I fill them with the silicon bronze. It works well. After grinding it and hammer & dolly work, it ls very smooth and doesn't need body filler. I want the underside of the floor to be paintable and look nice, so I used this technique on the visible side.
This piece has a few more patches needed so I will keep going here.
