- Thread starter
- #81
Maybe.Ok so this being a LX forum and the LXs built in 2025 were built in Japan, that means the 2025 LXs would have clean engines (due to this process). Did I read that right?
I've spoken directly to the owner in said thread on Tundras, so yes, that is my source.What, really? This is your source? Like one guy in the Tundra forum that obviously had the bad luck of getting a lemon down his throat. This is a far cry from "2025 hybrid V35s are all plagued with the same issue as the non-hybrids and will, NO DOUBT, be all subject to a recall."
Yup. Anything Mid 2025 and after MIGHT not have any engine issues. We don't know yet.Sudo - Got you to: "V35A is maybe ok in the latest LX". My work here is done
That is as far as you will get, probably.Sudo - Got you to: "V35A is maybe ok in the latest LX". My work here is done
Fact: They f ed up major league big time, Its costing massive pain in dollars (engines), loss of service techs, and this will lead to lower sales.
Well, your confidence is misplaced. I use to be that way too, but the new Toyota/Lexus is not the Toyota/Lexus of old.Honestly, as a late 2025 LX700H buyer, I am little concerned with this potential-maybe-could've-kinda engine issue 3 years later after the problem has been identified. I have enough confidence in Lexus/Toyota to not believe that, after knowing of this issue for the last 3 years, they have not changed the process that initially caused it and are currently installing engines plagued by the same issue.
The LX is included up to April 2024, so for @dms, it wouldn't matter.Purchased or build date?
Tahara is ALWAYS going to be ahead of Alabama when it comes to changes.Interesting. It sounds like Alabama was behind Tahara on implementing the manufacturing process improvements. And also behind on updating their line to receive and install the "improved #1 main bearing". (hillbillies...)
As a result the recall for Tundra's could still be expanded to additional units - up until Alabama started installing the updated main bearing, which they don't tell us when this occurred.
While the affected production periods for Tahara models should be finalized.
Regardless, -if- you take Toyota's word, any NEW Tahara or Alabama made model should be good by now.
This is called Japanese pride.It also seems like they were much more worried about Alabama as they did daily swab tests on those engines but didn't feel it necessary to do it in Tahara.
It looks like my build date was 11/23. I was worried about hitting the 50K mile mark next month and warranty coverage. Now it looks like that problem may have been solved. It will be interesting to see if they have any issues with the fact that I had them use 5w30 at my 40K oil change.Purchased or build date?
And yet the #1 Main Bearing continues to fail, including a 2025 model year Tundra TRD Pro. The issue was not resolved in the 2025 model year, whether from Tahara or Alabama.
