Thank you! I have had so many good memories and still making more with the 80 that I just could not do it!Love the Tan 80... Congrats on the 200
Same boat here... I just don't think I'm capable of managing two ladies in my life at the same time, but would love that mindset![]()
38 Toyos MTs! Those are my 4th set for her. Just awesome! What brand 35s would work? And, when you say little work, trimming or other stuff? Thank you!Loving the 80. What size tires do you have under her?
35s can be done on the 200-series with a little work. 37s have been done too with more drastic efforts.
For 35's - either tundra front end swap or Slee KDSS swaybar relocation bracket, a lift, uca’s, correct offset wheels and fender liner trimming.38 Toyos MTs! Those are my 4th set for her. Just awesome! What brand 35s would work? And, when you say little work, trimming or other stuff? Thank you!
I just dropped 7k on parts to do the Tundra front end swap with Kings. Are you telling me all I need to do is run 30mm off set wheels? Also, I do not believe it is possible to run 35x12.5s with out going full blown Artic truck style and cutting out fenders
theres lots of threads on this info buried in here
38s! Beefy.
There's several different strategies to fit 35s. Probably the most important thing is to use the right offset. Too little, and you rub the KDSS bar. Too much, and the additional swing of the tire as it steers, creates issues itself. Narrower 35s will give more leeway. For a full 35x12.5, you really want an offset of ~30-40mm.
That offset (pushing tires out) can be achieved with wheels, wheel spacers, or the tundra swap mentioned.
One thing that is different between the SFA 80 and IFS 200, is that lift in an IFS doesn't really add clearance. This is because the suspension stroke in an IFS is the same regardless of lift. Lift only changes the neutral/at rest point. It will still travel the same stroke when compressed, and so one therefore still needs the tire to clear when articulating.
A common strategy to fit the 35 is via upper control arms. To fix the alignment due to larger lifts, and potentially to move the tire a bit forward in the wheel well to maximize clearance at the aft part of the wheel well. There, it requires some plastic trimming. Another strategy for clearance at the rear is a body mount chop. Just the very non-structural corner where it might contact the tire, if not pulling forward aggressively with the UCA.
