25 FUEL SENDER UNIT WIRE TRAJECTORY? HELP
Costa Rica
Hi hello wondering if you could help me I just installed a new fuel sender unit on my 25, but since it didn't had one when we bought it I don't know the trajectory of the wire. I superficially checked older threads but can't really find were the wire traverse. It just doesn't seem right to take it out were the fuel line exits the cabin.
It does follow the fuel line, then joins the rear wiring harness, then to the 6 pin plug on the fire wall on passenger side, then to the fuse block. The stock wire was yellow with red heat shrink at the ends.
Stock set up also has a ground wire that follows along with the yellow/red wire to the harness.
Much obliged, Merry Christmas!
@fabianqm Check out post 166 in my build of Project Old Fart in this forum, I did not have the fuel hose on but this shows the routing. John
Great! Just what I needed. Your truck is just awesome!!, hope some day mine looks as good. By the way, you don't happen to have a photo of the back of the cluster? (With the cables attached)
