For Sale 24V Webasto Thermo Pro 50 Eco, Brand New
  1. 60 Series
  2. 70 Series
  3. 80 Series
  4. 90 Series
  5. LX450
  6. 100 Series
FIRESALE!!! $850
Brand New 24V Webasto Thermo Pro 50 Eco and SmarTemp Control fx 2.0 timer/controller.
I sold my diesel before I installed this. The whole set-up in the manufacturers original unopened packaging.
Webasto Website
MSRP $1600
Webasto SmarTemp fx 2.0 MSRP $200
This Webasto diesel heater is designed to perform in the most demanding off-highway conditions. Webasto offers an ideal solution for engine pre-heat, operator comfort and increased productivity for a wide variety of vehicles and machinery. This coolant heater is suitable for use on engines up to 15 Liter displacement. Preheating the engine eliminates excessive emissions due to cold starts, increased wear while running with cold fluids and can increase DPF service intervals. Uses as little as 1 gallon of fuel per 10 hours of run time.
  • Thermo Pro 50 24v diesel heater with heavy-duty, off-highway upgrade kit.
  • Heater type: Coolant
  • Hose Connection: .750"
  • Engine sizing: Up to 15L engine
  • Heating Capacity: 8,600-17,200 BTU (2.5-5.0kW)
  • Electrical system: 24v dc, Full wiring Harness included
  • Fuel type: Diesel
  • Fuel system components: Fuel tank pick-up tube, fuel filter, fuel lines and clamps, fuel pump.
  • Controls: Standard lighted on/off toggle switch.
  • Exhaust components: Stainless steel exhaust muffler, tubing & clamps.
  • Cooling system Components: 5/8" Coolant hoses with molded 180 degree bends, heavy duty constant tension clamps, Y-pipe connectors, splicers.
This Webasto diesel heater is designed to perform in the most demanding off-highway conditions. Webasto offers an ideal solution for engine pre-heat, operator comfort, and increased productivity for a wide variety of vehicles and machinery. This coolant heater is suitable for use on engines up to 15 Liter displacement. Preheating the engine eliminates excessive emissions due to cold starts, increased wear while running with cold fluids and can increase DPF service intervals. Uses as little as 1 gallon of fuel per 10 hours of run time. Heats whole coolant system, including heater core. Keep your cab comfy when parked or camping!
Contains:
Installation kit
Heater unit
Water/Coolant Pump
Fuel metering pump
Installation kit contains:
Coolant hose and connections with clamps
Wiring harness
Fuel line
Exhaust hose and exhaust silencer/muffler
Air intake hose and silencer
Fuel pump Bracket / holder
Exhausts clamps and holders
Fuel line accessories
