Hey All,
First off, this is my first 4runner and I'm not familiar with the engine so ... be gentle.
My roomate picked up a beater 89 [but second generation, 90+ body style] with a rotten body and 390K on the clock. He drove it for a couple of months before it started overheating and "puking coolant". He started to dismantle it with visions of taking off the head, but .. limited mechanical capability. He got tired of it / gave up and it has sat in the garage for the past couple of months. He was gonna s**** it, but I simply cant sit around and watch good trucks die, so I bought it off him for a case of beer.
So, poked around and determined the leaks were block heater and water pump. Fixed both, changed hoses, thermostat, all the good stuff. Roomate had partially dismantled a bunch of things - I really have no idea what all was touched, but exhaust manifold was sorta-kinda off, air cleaner was removed, belts and pulleys were off. He says vacuum hoses were untouched. The truck had an intermittent surging idle prior to the surgery.
So, buttoned it all up, hooked up everything I could see, charged the battery - holds fluid, cranks, catches, runs beautifully at about 1000 rpm.
then it dies.
about 2 seconds of run time and then she just dies. not a stall, just plain dies. and it doesn't matter what RPM its at, also dies if no gas is applied - sounds like some sort of engine shut-off. Does a 22RE have something like that? / any other ideas?
Sorry if this is a rookie question, I tried the search and was unproductive. Thanks in advance
Cheers,
Crash
then it dies.
Cheers,
Crash
