My 22r is misfiring and burning rich in number 4 cyl. All the other plugs are normal color. Just the 4th is dry black. Not oil.
I did compression test all 4 cylinders at 150.
Changed plug wires. Rotor. Cap.
Seafoam the engine.
New intake gasket. Exhaust gaskets. Fixed vacuum leaks.
I been thinking stuck valves on number 4 but not too sure. I hear slight clicking when I get close To the head.
Not sure where else to go from here. Alot of threads say maybe a carb rebuild kit.. But I can't see how a carb rebuild is needed just because 1 cylinder. Wouldn't a carb needing a rebuild make all 4 cylinders run rich not just the 4th??
Seafoam the engine.
