- Joined
- Sep 22, 2018
- Threads
- 88
- Messages
- 1,105
- Location
- Noblesville, IN
- Website
- www.edmartintoyota.com
- Year
- 2019
- Vehicle Model
- 200 Series
- Mileage
- 35000
- Color
- Gray
2019 Landcruiser - Magnetic Gray with Terra interior
For sale at Ed Martin Toyota
Call, email or text Eric Sarjeant for inquiries
esarjeant@edmartin.com
317-385-9572
Suspension & Drivetrain
- King 2.5 Coilovers with remote reservoirs and compression adjusters, extended travel with 800lb springs up front and OME 2723 in rear, red front springs and black anodized components.
- SPC upper control arms (recently serviced)
- OEM 10mm coil spacer up front
- Timbren bump stops
- re-geared with 4.88 Nitro gears
-ARB twin motor onboard air compressor
- ARB air lockers, front and rear
- Diff drop
-ARB diff breather kit
- Slee KDSS relocation kit
- Icon Rebound wheels, 17x8.5, wrapped in Toyo Open Country R/T Trail LT285/75R17 (including spare)
Exterior Mods and Armor
-Rhino Evolution front bumper, color matched (1G3)
-Warn Zeon platinum 12k winch, synthetic winch line and Factor 55 Flatlink
- Budbuilt rock sliders w/ diamond plate
- Budbuilt Stage 2 skid plates in 1/4” aluminum
- Fabulous Fabrications aluminum snorkel
- Kut Snake fender flares, color-matched and custom molded to rhino bumper
- Blacked out trim, front grill and emblems (painted)
- Ceramic coat (including underbody)
- ARB recovery points
- OEM JDM window visors
- Custom Gamiviti roof rack with integrated Renogy Eclipse 100W monocrystalline PV panel, light bar, scene lights, and wired for tent/aux light power. All wiring to rack uses waterproof Deutsch connectors so rack/lighting/PV panel can removed as a single unit as needed.
-WeBoost Drive-Reach cell booster with custom antenna mount
Interior Mods
-window tints & windshield tint, 20% front two windows, 85% windshield (ceramic)
-full interior dynamat sound deadening
-Husky all weather mats
-Stedi switches in OEM panel locations
-Hidden air-locker kill switch (driver side center tunnel mount rocker switch)
-Switch-pro control panel concealed in sunglasses holder
-BMS Redarc Manager30 control panel concealed in glove box
-Trekboxx Alpha rear drawer system with custom integrated electrical, can be setup for fridge/full cage, fridge/no cage, or drawers only
- Original rear seats included, never used
Lighting
-Custom blacked-out headlight surrounds
-Rhino 60W Cree fog lights w/ amber film
- Rigid midnight edition SR-series Pro light bar, 40” (concealed behind air diffuser)
-Rigid 65 deg scene lights, amber (x2)
-Rigid rock lights, amber film (x6)
-Rigid midnight D-Series diffused rear lights, custom mounted in rear reflector positions
-Custom hatch light
Auxiliary Electrical System
-BMS - Redarc Manager 30, custom mounted control panel in glove box
-Battleborn LiFePO4 100Ah Aux Battery in custom mount
-Switch-pro 9100, custom-mounted control panel in sunglasses holder, controls all aux lighting, compressor, cell booster, & fridge power
-Samlex PST 100 Pure Sine Inverter
-Shore power plug with waterproof housing custom mounted under vehicle, with custom-made extension cord (included)
-Stedi switches in OEM locations
-Custom mounted kill switch for ARB air lockers
-Blue-sea isolation switch in engine compartment (isolates the aux battery circuit from the main vehicle battery; when not isolated will charge aux battery via alternator)
Rear Drawer System Details
-Trekboxx Alpha system
-fridge slide topper panel, creates flat floor when not running fridge / full cage
-left rear panel with BlueSea OLED battery charge indicator, 12v port and USB 2.0 charge ports, plus switches for hatch light, battery charge indicator and aux tent/awning lights
-right rear panel has 120w plug and on/off switch for inverter
-under left wing is Switch-Pro module, auxiliary battery, and wiring plus Blue Sea marine-grade fuse blocks.
-mounted to the rear of Trekboxx (behind rear seats) is the inverter inside a custom housing
-under the right wing is the Manager30 BMS unit.
2019 Toyota Land Cruiser Base in Noblesville, IN | Indianapolis Toyota Land Cruiser | Ed Martin Toyota
Research the 2019 Toyota Land Cruiser Base in Noblesville, IN at Ed Martin Toyota. View pictures, specs, and pricing & schedule a test drive today.
317-385-9572
- Diff drop
Interior Mods
Lighting
-Custom hatch light
