Pro tip: always remove that fill plug firstI will add that servicing the 3 differentials is easier than changing the oil. The hardest part is taking the front skid plate off. Any semi reputable mechanic could do the work. Do you have any independent shops around that you would trust to do an oil change? If so, check with them.
The work is as simple as: pull the fill plug, pull the drain plug, replace drain plug, fill with oil until it spills out the fill hole, replace fill plug.
