For Sale 2011 AT Overland Chaser Trailer and RTT
FOR SALE: 2011 Chaser Trailer from Adventure Trailers, Inc. Original Owner. Purchased new in July of 2011 and equipped with the following:
  • Chaser Trailer Kit VIN Chassis, Trailing Arm Suspension with air struts, Cargo Box with gas strut assisted lid, Drop Leg Jack, Rubber Matting, Cargo Tie Downs, 2” Rear Accessory Receiver. Standard Powder Coat Color: White with Black Chassis & Fenders
  • Steel Powder Coated Nose Box
  • Two AT Gas Can Holders (Scepter or NATO) for Trailer
  • 19 Gallon roto-mold water tank with 1.25' opening, 1/2' drain plug and pump
  • Stainless Steel sink with drain hose
  • Fiamma F35 Pro 2.2M, brackets with double extension brackets
  • Electric Braked Axle Upgrade with 10' drums, includes break-away kit
  • Utility shelf for Chaser (16.5' x 43' x .75'), shaped and finished hardwood ply with locator pins
  • Auxiliary 12V Power wiring w/ night light, 3 fused outlets, battery tray and hold down
  • ARB Adventure LED light
  • AGM group 31 deep cycle battery
  • Noco Marine Charge On board 10 Amp single battery charger & maintainer with Shore Plug Installed
  • Chaser Tail gate 16' x 32' with locking T-handle latches
  • Multi Axis Coupler, 6000 lb, Class III
  • Swing away tire carrier
  • Transit Slide Lock for Engel MT35 & MT45 Fridges
  • 6 LED Rectangular HD Flood Light 4'x6'
  • 5 lb Manchester propane cylinder
  • AT Custom Aluminum 5 lb Propane Cylinder Bracket & clamp
  • 28" Waynes RV Stabilizer
  • 3 TOYO Open Country ATIII 255/80/17 (purchased 03/2023) on Toyota FJ Cruiser Steel Rims
  • Wheel Adapter: 6 on 5.5 to 6 on 5.5, 2" thick, for use with stock rims
  • Thule track rack and cross bar system, 2 tracks, 6 feet, 6 towers, 3 cross bars
  • Eezi-Awn Series 3, 1400 Roof Top Tent 54' x 96' Beige
Always stored indoors this trailer, tent and all the equipment is in excellent condition, has no known issues and is ready for your next adventure. Located in Houston, Texas. Price: $10,000.00
Additional pictures and video are available upon request.
Thanks,
Kevin Vincent
kv01@comcast.net
Still available?
