I believe it to be more of an age thing and usage thing then high mileage. Seems like most 08 are getting it now.
Not sure about that. My 08 has only 77k on it and I've seen no signs of that crack. Maybe it's a pressure thing over time...?
Mine cracked and blew pink stuff all over the place, not sure how long it was leaking until I saw pink fluid on the garage floor. I called Toyota told them about it, and how this was my 5th LC and shocked that the radiator blew at 110K miles. They where very understanding and in 3 weeks cut me a check for $1000 +/- as reimbursement ( I had it replaced at the dealer)
Well- I also called and gave my best professional request for some kind of reimbursement from Toyota Care.
They were extremely professional and gave me $500 credit for future parts or service. No expiration. I plan to use for parts on 15%off Tuesdays at my dealer to maximize that value.
Mark- Yes. Called Toyota Care from the website. Followed the prompts.Nice. And you are well beyond warranty, correct?
Who/where did you call, exactly?
Mine blew at 129,000 two days ago. I changed the spark plugs a few weeks ago and visually inspected that area of the radiator because of this thread. I didn't see anything to indicate imminent failure.
Mine blew at 112k. Bought one off Amazon as my Toyota dealer couldn't get me one for weeks. At 140k now and so far so good.Has anyone used an aftermarket radiator for replacement?
What are they charging you for OEM?My shop ordered one this morning, OEM. I don't have an issue yet but am heading to CO pretty soon, don't want to risk it. With 130k+ miles, seems I'm in the sweet spot for failure.
Water pump failure is so common (mine is starting to seep at 89K miles) that replacing one around 100k miles is just a good idea. Before I do the water pump I'm trying to decide if I should do the radiator at the same time. What I'm trying to figure out is just how likely the radiator is to fail. Is it as common as the water pump or am I just seeing posts of the vocal unfortunate few that just happened to have bad luck?
