My 2006 LX470 is about 3 months old to me, and I’m trying to troubleshoot an A/C issue.
When I bought the truck, the A/C would not blow hot air, so I replaced the A/C blend door/servo motor. After that, the temperature control started working, but I didn’t realize there was still an issue with the cooling performance because the weather was cold at the time.
Now that I’ve been able to test it properly:
- Front A/C vent temperature: around 64–66°F, even with MAX COOL and the lowest temperature setting.
- Rear A/C: much better, around 45–50°F.
- I also fixed the front cabin temperature sensor/hose issue.
- Error 41 is still present even after replacing the servo motor.
- If I increase the temperature setting, the front vents do produce hot air, so the temperature control does appear to be functioning to some extent.
- The original refrigerant was removed and the system was recharged with approximately 2.3 lb of refrigerant, as recommended.
- I noticed the large/thick cylindrical section of the suction line near the passenger side does not get very cold when only the front A/C is running. However, it gets noticeably colder when I turn the rear A/C on. I will double-check this observation.
- With the front A/C on MAX COOL, FACE only is about 4°F warmer than FACE + FEET. This seems like a strange observation to me.
