2006 LC Dying
Texas
Hello everyone,
I have a 2006 Land Cruiser that recently died on me a few times when I stop. It is hard to explain but I can't accelerate and the starter tries to start but no luck. I sit for about 5 mins and then it will start and run like nothing happened. The check engine light has never come on. Anyone else had this problem?
Thanks,
Txyota
Original fuel pump?
  • Like
Reactions: GTV
Hello everyone,
Thanks,
Txyota
how much fuel in the tank when this happens?
Sounds an awful lot like the fuel pump. low fuel warms up quicker/easier making a tired pump take a nap. The dealer needs to provide the info they have disproving the pump...otherwise I'd be hitting up RA and nabbing a new one.
I agree. I appreciate your help.
There have been a bunch of forums on here where people have similar symptoms and it leads them to the fuel pump. Most people say they are chugging up a hill when it happens or coming to a stop.
How many miles on the original pump? Report back if you swap it out and that fixes the problem. I've been debating replacing mine lately but I am also trying to dial back the, replace it before it breaks motto. It gets expensive.
Also avoid shady gas stations and try next fill at a higher end station and see if it helps. There was recent news that some stations were caught mixing water in the gas tank :mad:
It has happened to me as recently as this week. Scenario is higher altitude (just outside of Loveland CO), hot ambient temp (92F) and few that has an indeterminate % of ethanol (pump says up to 10 but some claim that in South Dakota and Nebraska the number is a suggestion, not a rule). I drove Wednesday straight thru from Minneapolis to Loveland/ Boulder area and at the last fill up (at a Sinclair) I second guessed myself and just used straight 87. The girl laid down at a stoplight and I was barely able to nurse it to the shoulder. Let her cool 20 minutes and flipped around to fill her up with Premium and not a problem since.
I have found if I run Premium if the temps are above 90 I don’t have a problem.
These gas stories make me wonder if it would be a good idea to carry those little plastic bottles of octane booster for long road trips.
Fuel pump. Been there done that.
