2005 FZJ80 Needs Help
OR
I have a problem with my 95' FZJ80 that my Toyota dealer cannot determine.
#1: the engine shutters/ boggs when trying to pass 2-3rd. At Idle, the engine revs smoothly. If you pass 3rd. it runs normal IIRC
#2: Engine has a whinning sound at idle. and whine sound increases higher as you rev the motor; sound like a transmission whine but how would it make that whine sound when in neutral?
Mileage is 148k,
Had the head gasket replaced at 78k as a PM measure
Exhaust has leaks and the O2 sensor occasionally pops out and needs to be set in. Could a O2 sensor sending bad signals be the problem I am having?
1: check the wiring harness near the EGR pipe. The engine might be rocking during the shift, causing shorts.
2: what kind of belts are you running? The first thing I would do is put on Toyota belts and tighten them properly.
78k is a new record for head gasket PM.
Running OEM belts and had them inspected ----(unsure if this is means anything anymore because millennials are the mecahnics)--- at the dealer; they said they were good. I will check the wiring harness.
Correction HG was 86k :) ... I saw the bores when the head was off and had perfect cross hatching.
I may get a new OEM exhaust bc I am sick and tire of dealing with Meinike
Whine could be power steering pump... it would fluctuate with rpm.
Sounds like under load, your having issues. I agree with @gummycarbs about the wiring harness where the egr is can make the wires bad, thus injectors will not fire.
You might also look at fuel filter, pressure regulator on the fuel line and finally clean the injectors.
