2004 No crank when starting
Ivins UT
Website
bret.io
My wife started complaining about a clicking near the ignition or dashboard the other after starting the car fine, but a few days later, the car will occasionally not crank.
- You turn the key to START, the radio/nav cuts out (like normal), but then there is simple no crank.
- No luck when switching to neutral
- Waiting a bit and trying again, and it cranks fine. (So far this has also involved popping the hood and relay box cover)
- Happens after you drive it and then park it and let it sit for a bit
- I tried swapping the STR relay with a newer one, and it still happened again today
- Battery tests good, terminals are on tight and clean (its not a power cut out
- Its been pretty hot out but the cars done fine in hotter.
TODO:
- Voltage Test of SRT terminals While its not cranking to see if the relay is getting power
Any ideas? Has anyone else encountered this issue? This is a WAF (Wife annoyance factor) 10 here!
I think I solved it, bad EFI 20A fuse:
