2004 Lexus GX470 VSC & ABS fault code help
Detroit
I have the following codes for ABS:
32 & 41
I have the following VSC codes:
39 and 43
all codes obtained by flashing ABS and VSC light pattern observation.
Can anyone with a factory repair manual assist in explaining what these codes mean?
If all the lights are on it can also be your gas cap unless you have other mechanical issues.
Just off hand have you tried the zero point calibration? Also have you done anything that may have jeporadized the Speed sensor wires?
what is zero point calibration? I have done no work on this vehicle in months but if the codes meant something is wrong it will help point in the right direction. I don't want some dealer telling me i need a new expensive brake booster actuator when I don't need one.
