2003 yukon running lights
Mace
rock scientist..
Staff member
s-Moderator
Moderator
Las Vegas
Anyone have the P# for the daytime running lights on a 2003 Yukon?
And how they install would be helpfull too ;)
I have not looked yet.
You talking the front clear ones?
It's not the bulb, it is the socket that is bad. They are common for failing and GM charges 1 hour plus parts per socket.
yeah, the front clear ones.
so a bad socket is about $100 to replace?
I think I'll do it myself.
They probably have the socket at autozone
The socket isn't always the problem, pull the socket/bulb and check it. You just twist the socket 1/4 turn or so and it will pop out.
This is not a 1157 style bulb that simply twists out, it is a "Wedge" sylvania #4114K
The socket that takes this bulb is a super weak link in GM SUV's and Trucks. # for the socket is 15306157 $21.50 and the bulb is #15199562 $3.42
Flat rate is one hour to replace the socket which requires cutting the harness and installing the new socket.
I have sold 100's of these, since most are bad.
Shane
Bulb was burnt out. Socket was ugly. New bulb works fine.
And it is a 4157 or something allong that number not 4114
Though I can't for the life of me tell the difference.
One is the GM number by Sylvania.......Glad the buld was the problem, Now look at all late model GM's and you will see that alot have one that is burnt out.
Let me know if this is a solid fix as they tend to pop quickly after installed.
Shane
Sylvania had the 4157 number as well. I did replace it with a 4114 and it works.
Like I said, i can't tell the difference.
I am positive that it is a short term fix. Bt at least I have daylight running lights for the drive to Phoenix tomorrow :D
