2003 LX 470 AHC Delete?
Jackson, WY
I have a 2003 LX 470 AHC with around 230,000 miles. I love my AHC, but it is now leaking dramatically from a line that connects to the front left shock and also less dramatically from both front shocks. Toyota dealer wants $2,300 to fix. Seems like it's probably time to delete the AHC. I use the car as a daily driver and I also drive about 60 hours each summer on rough Forests Service roads. I don't do serious overland. I haven't done any modifications to the vehicle. Looking for an economical fix that will allow me to keep doing what I'm doing. I'm handy but I don't think I would be able to do my own suspension work. I've been reading threads on this forum about AHC delete, and thought I would pose the question again for my specific situation: What do you recommend?
To my knowledge, "deleting" the AHC requires changing the "shocks" to conventional LC shock absorbers. Which also requires changing the LX springs & torsion bars to conventional LC springs/tbars, because AHC "shocks" augment LX springs/tbars to support part of the vehicle weight and act as damped springs, so changing to conventional shocks requires the stouter conventional LC springs/tbars.
The conventional LC shocks also require their own washer under the top nut, the LX version has a flat so it won't work. (Unless you have beefy drill bit and drill press/clamp to drill it out.)
I converted my 1999 LX in 2010, because the AHC Accumulators had leaked down requiring replacement. OEM springs, torsion bars, and shocks were less expensive than Accumulators, which evidently require replacement about every 10-12 years due to nitrogen loss, plus the fluid for the Accumulator changeout. The conventional gear will last a lot longer than AHC; conventional springs and tbars will outlast the vehicle.
I trained and did a fair amount of suspension work as a pup, some in later years too, this conversion is not the most difficult suspension work. But if one is not comfortable doing suspension work I would not try to convince him to try it. (Lest anyone take offense with my terms - have you ever seen a woman doing suspension work? The answer is no for a reason.)
The AHC was truly magical when this vehicle was new. I much preferred it to the LC conventional suspension it now has. But c'est la vie, the AHC is too expensive to keep going long term. Maybe that is one reason LX470's seem to be getting more rare these days.
:popcorn:
Is your leaking line rusty? If so it's a no-brainer - convert. If you're handy it's certainly something you can do. Watch some videos before you make the call. The conversion parts don't cost much but you will have to get the washers out of Japan. AHC is great and generally durable but in a 20+ year old vehicle it can't compete with a conventional suspension for maintenance cost and peace of mind.
There's not a ton of rust on this car. The line is leaking from where it connects at the top of the shock. My local mechanics won't work on it. Toyota says they will fix it but more stuff can go wrong. I like the idea of having a system that my local guys can work on if necessary. Would something like this be a good idea: 100 Series/LX470 Stock Height Replacement Suspension Kit - Fits 1998-2007 100 Series/LX470 Applications (OME100STOCK) - https://cruiserteq.com/100-series-lx470-stock-height-replacement-suspension-kit-fits-1998-2007-100-series-lx470-applications-ome100stock/
Yes. I think don't change out the torsion bars unless and until you perceive the need. Many people are happy with the LX bars re-indexed by a couple of splines, depends on how much weight you are adding if any. You can overdo the TBs and end up with a very harsh ride. You can do better than that on the washers at Impex in Japan.
I just completed an AHC delete on my 04 LX and it was a bit of a project. Mine was quite rusty, so every line was junk and most of the nuts and bolts holding the components to the frame were rusted beyond easy removal. The biggest fight I had was getting the upper nuts off of the rear shocks. I ended up just cutting them with a torch depsite not wanting to get in there that close to the floor with it, it was the only way.
On a rust free vehicle, it wouldn't be too bad of a job, a weekends worth of work in a driveway or garage floor. I removed everything associated with the AHC, but you could leave lines and components where the4y are if you want a quick swap, though it will probably leak fluid for several weeks as the lines drain down.
Using the original LX torsion bars without the AHC support will overload them, they will be twisted and stressed beyond design range.
Maybe they can be indexed to achieve correct ride height, but this only masks the overstressed overtwisted condition.
They may last for a while like this, but premature failure is a distinct possibility. (Unlike all-OEM condition where they will outlast the vehicle if properly designed and made as with Toyota.)
I wouldn't do it.
I wouldn't do it.
There is a considerable amount of evidence that this is "mud myth". There has been a lot of people, on this forum and elsewhere, who have been perfectly happy with the LX torsion bars for years on end. A great many LX owners don't add weight and don't engage in serious off-roading. One of the defining characteristics of torsion bars is that they are adjustable. There's no evidence that re-indexing by a couple of splines is stressing beyond "design range". There wouldn't be so many people doing it and happy with it if that was the case. Which is why I say don't change out the torsion bars unless and until you see a need. It's easy to do it later if necessary.
Got another opinion from a local mechanic on my AHC. They suggested the same repairs as the dealer: new front shocks, and new left front supply line. $2,800 including alignment. I was starting to lean towards trying an incremental fix of just the line, but now I'm back to leaning towards a delete. I called Cruiser Outfitters and discussed the options more thoroughly. Seems like this is what fits my needs the best:
100 Series/LX470 Stock/Light Load Replacement Suspension 1.5" Lift Kit w/ Torsion Bars - Fits 1998-2007 100 Series/LX470 Applications (OME100STKTOR) - https://cruiserteq.com/100-series-lx470-stock-light-load-replacement-suspension-1-5-lift-kit-w-torsion-bars-fits-1998-2007-100-series-lx470-applications-ome100stktor/?searchid=0&search_query=ome100
Shock Washer Kit - Fits 100 Series/LX470 Non AHC Applications (SUS100SHHWKIT) - https://cruiserteq.com/shock-washer-kit-fits-100-series-lx470-non-ahc-applications-sus100shhwkit/?searchid=0&search_query=SUS100SHHWKIT
They seem to feel I won't need a differential drop, but I will need the torsion bars.
I would like a smoother ride than what people say about the OME shocks, and I don't have extra weight on the vehicle when I'm driving forest services roads. I do spend about 50 hours per year on rough roads, that sometimes require me to go slow, but I never have clearance issues.
My other local mechanic wants around $1,700 to do the conventional install.
In the meantime my AHC is low on fluid and stuck in low, but it still rides better than my Subaru Forester. Can I run like that indefinitely? Should I pull come fuses out to keep the pump from running?
Good to know, Why does Cruiser Outfitters put OME springs and tension bars matched with the OEM shocks in their conversion package? Maybe the OME stuff is a bit of an upgrade for off-road?
Full disclosure, I'm one of the folks who loves AHC, and feels that it meets my needs for any off-roading that I get up to (305k mile LX btw). In High mode it has the same capability as a conventional lift kit, but the ability to run it in Normal mode on the comfort setting is huge in terms of comfort level on regular fire roads, washboard roads, etc. which is the bulk of what most of us do. Not to mention the on-road driving characteristics, which definitely get noticeably worse when you go to a conventional lift.
Anyways, keeping AHC is seeming like a terrible option for you becuase you're looking at the cost of keeping it if you have a shop do the work for you, but fixing the AHC yourself is a much more simple option than ripping it all out for LC TBs and a conventional lift kit. People are sometimes overeager to do so because they feel that AHC is too complex, but it's genuinely not bad and the pros outweigh the cons imo, especially if you're only doing daily driving and hitting some mild forest roads. I'd replace the shocks, flush and refill the AHC fluid, and go from there. If you cycle the AHC between High and Low modes, and you're seeing a drastic enough difference between those two fluid levels in the reservoir, then your problem is solved, aside from maybe needing to patch that one line (assuming it's bad).
Read through the ABC's of AHC thread in the pinned FAQ, and make the determination for yourself. When you make posts like this one, all you'll get are responses like mine (AHC is the best thing since sliced bread, and here's why) or responses like some of the others in here (AHC is a pariah, ditch it ASAP).
I appreciate your input. I love my AHC, but It seems like $2,600 to have the shop do my front shocks and front left supply line is too much. If I had an AHC that was not leaking I would totally keep it. I changed the fluid last summer and it seemed like my gradations was around 7 which is not great. Now with the leak my reservoir is emptying every week. I've been going back and forth about doing the delete, but I'm currently leaning towards replacing the AHC with OEM LC shocks and EMU springs and torsion bars. I feel like I've been learning a lot in the last couple months. I can't believe that I bought this car 6 years ago and didn't even know what AHC was or that I had it. My previous car was a 2001 LC.
Yeah, AHC definitely requires troubleshooting & wrenching on it yourself for it to make sense, financially or otherwise. I don't blame you one bit. I'm sure you're not the only one to daily drive an LX and not know what exactly the system is! Even the Lexus dealership is completely useless if I go to the parts desk and try to have them look up the AHC fluid; they've got no clue what it is, and I have to literally tell them what part number to enter into their system haha.
I bought the Cruiserteq stock LC shock conversion kit with OME springs and torsion bars. Nice guys. Very helpful. Local mechanic will install on Monday. Now I'm worried that my rack and pinion is too loose to align. I guess we shall see.
My mechanic did the conversion (Cruiserteq stock LC shock conversion kit with OME springs and torsion bars. I also needed to order all the special washers). Mechanic said the torsion bars were really hard to install and charged me more. He didn't disable the AHC and as I was driving on my first test drive the car lurched to the left and the traction control alert sounded. I took it back and he did some disconnecting. My "Off" light is still blinking, but no more lurching. It's been a few weeks now and the truck is performing very well. I've spent at least 10 hours on rough forest service roads. I like the ride of the conventional set up. Feels nice on the pavement and works great off pavement. I would definitely have kept the AHC if it hadn't had a catastrophic line leak, and moderate leaking from the front "shocks", but I feel good with my decision to convert based on the performance I'm getting and avoiding future trouble. Cruiserteq was very good to work with. Good advice. Responsive. There was a missing part in my washer order and they expedited getting me a replacement. My rack is too loose to align completely, but I'm not having any trouble with the steering pulling to the right or left, and I haven't had tire wear problems in the past, so I'm holding off on the rack replacement until I've digested the cost of the AHC delete.
With regard to your still blinking light, did you or your mechanic remove the AHC circuit breaker? Mine was removed and I don’t have a blinking light. Maybe the gurus can weigh in.
