2001 Lexus LX470 228K Clean Carfax
Pensacola, FL
located in Pensacola, FL
looking to get 7,500 Firm.
beige metallic pearl exterior
tan interior
wood grain
Navigation (missing disc)
Mark Levinson Sound system that works, multi Disc works and radio works antenna goes up and down haven't tried tape player.
I have A LOT of maintenance records from vehicles past along with receipts
Factory roof rack with cross bars
The Bad
-Only have valet Key, (the grey handle one no transponder) quoted 150 for replacement key)
-Hood struts worn out.
-Driver front fender was repainted.
-Missing cover for drivers vanity door light.
-Drivers rear door and quarter panel have some decent dent.
-Missing carpet in third row and on lower gate.
-Shaved emblems off rear hatch.
-A few speaker covers missing fabric covers
-Missing Navigation disc
-Missing the factory transmission Skid plate
-third row was removed, seat belts and all, but I have the hardware to be reinstalled
back of the second row seats are a little chewed up due to brackets on cargo box
The Good
-Ironman 4x4 Front bumper
-Badlands 12k winch
-National Luna Dual battery set up
-New Alternator with lifetime warrantee from O'reilly's 227k
-New Timing belt 228k
-New Crank Pulley 228k
-New front main seal 228k
-New Hydraulic Timing belt tensioner 228k
-New Clutch fan bracket 228k
-ARB Single Compressor that can Lock 2 differentials/or air up to 35" tires
-ICON stage 1 suspension kit
-ICON Overland Springs
-SPC upper control arms
-ARB torsion bars
- New wipers front and rear
-Scanguage II connected to OBDII port to Display engine parameters
-RCA and power inverter Plug mounted in void space on back of center console, power inverter is located under the dash.
-Led interior light conversion
-A/C works, Heat works, rear A/C works
-Custom storage box located in rear for overland/off road/ recovery gear.
-Power cables ran from Standby battery to rear behind second row for fridge/freezer connections.
the timing belt, crank pulley, hydraulic tensioner, front main seal, and clutch fan bracket all have 3 year 36k warranty from Evans automotive in Pensacola, they will reimburse any mechanical issues. on parts installed. clean Carfax.
