2001 front diff on a 2003 LX470
calgary
Hello people!
I am wondering if anyone has installed a 2001 LX470 front diff (or just ring and pinion) on a 2003 LX470?
Are the mounts the same? I am aware that the rear diff gear ratio would have to be changed as well.
I blew the front diff on my 03 lx470 and just looking for different options.
Thank you in advance
No you cannot. If you have a 5-speed transmission in your 03 then you have to use an 03-07 front diff with the 4.10 ratio.
98-02 were 4.30 ratio in the front
Car-part.com is a good place to find used front diffs, (also called carriers)
EDIT: I re-read your post, but ill leave that info above. Are you trying to go from 4.1 to 4.3?
It APPEARS that the carrier itself is the same part # across all 1998-2007, so the should be the same.
That is from a quick search showing parts 41101-60170 and 41320-60010 working for all.
