2000 Land Cruiser Prado TX bonnet (hood) fails to lock or stay latched
Calgary
Hi all!
My bonnet mechanism is not locking/latching. Imbricate it but no help. The bonnet opener latch inside is still pulled. Any help will be appreciated.
White lithium grease. I have to do this once in a while on my 5th Gen 4Runner rear latch.
Edit: if you’re unable to get your pull lever to reset, you may have a bad cable too.
For the spring - are there Ace Hardware stores in Canada? Or can you find a spring online?
You might remove the entire latch and soak it in mineral spirits and clean it with a toothbrush. Then inspect it for wear and clean/lube or just replace it.
Hard to find full assembly but yes will try to find it.
Thanks
