- Joined
- Jan 25, 2008
- Threads
- 49
- Messages
- 672
- Location
- Birmingham, Alabama
- Website
- www.trucksplusinc.com
Long story short, family member has a 2000 4 runner lmtd 4x4 that sat undriven for 4 years. Only has 46K miles. Covered in grime, put a new battery in it and it did fire up, but had had a dead miss. Got the vavle covers and intake off, had 4 stuck vavles. All came loose, but on driver side bank, one of the actual valve "caps" has broken off, valve itself is not compromised. Its a round flat metal cap on top of valve where it meets the over head cam lobe. Only found one small broke part on top of the head, rest is floating around in motor somewhere. put a scar on cam lobe and on the head near that area, but should not effect the performance if cap is replace and scars sanded.
Has anyone had one of these caps break????
Engine has good compression across all cylinders except this one. My mechanic thinks remove cam, sand down areas with damage and repalce the valve cap. Any thoughts?
front end repairs and new lights, grill, and custom bent hood.
